2002 Corolla CE rear speaker replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2007, 02:34 PM   #1 (permalink)
View noxvil's Photo Gallery
Does anyone have any info on replacing the speakers in the rear deck of a 2002 Corolla CE?
I just can't seem to figure out how to remove the speaker grills. I've tried prying them off, but that didn't work.
I would greatly appreciate some info from anyone who has replaced theirs or might know how it's done.
Thanks very much.
noxvil is offline   Reply With Quote
Old 07-08-2007, 06:16 PM   #2 (permalink)
Feel the vibe.
vibebreaker's Avatar
View vibebreaker's Photo Gallery
are you putting in aftermarket speakers?
anyway, you dont pry off the speaker grill. you take the whole dash trim off. that means you have to unscrew the three things there around the third brake light. pop the plastic part off first before you do it. you should remove the two headrests and you have to get the seatbelts out of the way.
by the way, if you are not using the rear speaker mounting brackets, i would like to buy them from you.
vibebreaker is offline   Reply With Quote
Old 07-08-2007, 11:05 PM   #3 (permalink)
Thanks for replying.
Yes, I am planning to put aftermarket speakers in.
I do have one other question if you don't mind. I noticed that the seatbelts are running through the piece of trim. You mentioned getting the seatbelts out of the way. Will they have to be unscrewed/unbolted and removed?
I can't really say if I will still need the mounting brackets or not. It will probably be a week or two before I try to install them. I can get back to you about it if I end up not needing them.
Old 07-09-2007, 07:33 AM   #4 (permalink)
Feel the vibe.
nope, you dont need to unbolt or do anything complicated with the seat belts. if you look at the edge of the dash trim where your seatbelt is at, there is a cut so that you can slide your seat belt from the dash trim.
let me know if you will not need the adjusting brackets. i am dying to have it so i can install mine that requires it. the previous speakers (my first aftermarket speakers) came with adjusted mounting bracket so i chucked my factory brackets.
Old 07-09-2007, 10:23 AM   #5 (permalink)
Thank you so much for your help.
I'll be sure to let you know if I don't need the brackets.
Old 07-10-2007, 02:02 PM   #6 (permalink)
Feel the vibe.
thanks man.
Rear Speaker Replacement - Scion tC RanmaP 1st Generation (2005-2010) 2 04-20-2008 11:03 PM
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
Can someone please school me on the Corolla XRS? TitaniumSE Archived Corolla threads 3 08-03-2006 08:47 AM
Speaker cover replacement - rear deck tomm Audio, Video, and Security - Tech 0 09-11-2004 03:26 PM
