What is the best way to check for bad ball joints or tie rod ends? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2007, 03:46 PM   #1 (permalink)
View Valkyrie90AE92's Photo Gallery
AE92 What is the best way to check for bad ball joints or tie rod ends?
AE92.
My car tends to wander left or right, especially at hwy speeds. I have been suspecting either the tie rod ends or ball joints, but how do you test for them being bad? I think my shocks and springs are bad (200K on the car), but when it comes to steering, I figure the ends or joints had to be the culprit. The front has 175 70 R13 almost new tires, but it was doing it before I changed the tires, too.
Any suggestions would be greatly appreciated!
Valkyrie90AE92 is offline   Reply With Quote
Old 07-08-2007, 06:39 PM   #2 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
jack it up...
wiggle the wheel left and right. if it moves and the steering wheel does not then you need a tire rod end.
Put a prybar between the control arm and the kuckle and it you get movement, you will see the play in the ball joint. then well you need a balljoint, you can wiggle up and down as well but prybar is better, since a really bad ball joint can make it seem like a bad tie rod.
But if it moves when you wiggle it and the rotor moves with the tire and everything else doesn't.. then you need a wheel bearing.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 07-11-2007, 03:06 PM   #3 (permalink)
Well, I checked all of them, and there was no play. I did notice that my springs were so soft I could compress them with my hand. I would guess this is a good reason for the weaving left and right.
Old 07-11-2007, 04:59 PM   #4 (permalink)
Danno
View 89yotarollagts's Photo Gallery
^^ Also a good way to check wheel bearings
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
tie rod Q+A Redlyne_mr2 Hardcore Tech and Competition 5 01-12-2006 12:13 AM
iner tie rod: 100+ bucks from moog Zrain Celica Forum 2 04-08-2004 10:02 PM
driver side tie rod boot busted? jamesmetairie Archived Corolla threads 1 03-13-2004 02:06 PM
tie rod end ball joint grease refill? Nick Hardcore Tech and Competition 7 08-10-2003 06:38 PM
Does canadian tire rent out a tie rod tool... Redlyne_mr2 Hardcore Tech and Competition 4 11-11-2002 10:35 PM
