Recommended tire pressure - 2005 S - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2007, 10:58 PM   #1 (permalink)
View toyota_rave's Photo Gallery
USA Recommended tire pressure - 2005 S
Hi there,
I know the drivers' side of the 2005 S corolla states recommended pressure of 30PSI for the factory installed tires (Goodyear Integrity).
Has anyone went above that recommendation? if so, what are the pros and cons?
toyota_rave is offline   Reply With Quote
Old 07-10-2007, 11:35 PM   #2 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
i used to keep mine at 35 PSI, pro is u get better gas milage, cons, uneven tire wear and a harsher ride...
underinflated only has cones, more tire wear, pulling to one side, worse gas milage, worse handling, u name it
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 07-10-2007, 11:45 PM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
the pulling will depend if only one tire is underinflated. same with having the pressure of one tire higher than the others, messes with the handling.
If it's the stock tires read the door. Usually tires are kept inflated at 32 psi or more.
If the tires aren't the orignals then read the tire.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Low Tire Pressure Indicator Reset FYI Wizrd23 5th & 6th Generation (2002-2006 & 2007-2011) 5 04-29-2011 09:43 AM
Proper Tire Pressure w/Larger Tire??? MrSharkey 2nd Generation (2005+) 1 03-18-2007 09:02 AM
Anyone take out their TPMS sensors on a 07 yet?? Klutch 5th & 6th Generation (2002-2006 & 2007-2011) 14 09-08-2006 09:47 PM
tire pressure mendozer Camry & Solara Lounge 26 08-12-2005 07:29 AM
Tire Pressure Mr.Incognito Hardcore Tech and Competition 18 07-14-2002 05:31 PM
