Exhaust hole :( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2007, 12:47 PM   #1 (permalink)
"Only The Strong Survive"
View healsisbuckets1's Photo Gallery
USA Exhaust hole :(
i have a couple holes in my exhaust cause the kid who had the car before me thought he was a mechanic and decided to drill holes in it for a "racing effect" but now time comes for inspection and i fail for a cracked windsheild which i fixed ($220 down the shitter) and i failed for emissions and my friend was behind me on the highway the other day and he said when i pin it white smoke comes out of the muffler, is this the emissions or is it something else? thanks in advance guys
healsisbuckets1 is offline   Reply With Quote
Old 07-11-2007, 01:06 PM   #2 (permalink)
View Tavel's Photo Gallery
wtf? is it just on the muffler, or throughout the whole system? some kids are just plain dumb. lol.
I would suggest patching those up with an exhaust repair kit and see if the white smoke goes away. It could be water vapor entering the stream through the "speed holes", turning to steam and then condensing again when it exits.
otherwise it could be the engine running rich (likely bad O2 sensor) or even coolant entering the combustion chamber
What does your failure report say? HC, NOx, sulphur, etc...that will help pinpoint what might be going on with the emmisions.
the patch kits might last a year at best. you'll have to actually fix the exaust by either welding patches on or replacing the affected parts. (or have a shop do it, whatever). I bet its embarrasing to barrel down the road sounding like a rusted out junker
Tavel is offline   Reply With Quote
Old 07-11-2007, 02:05 PM   #3 (permalink)
haha the wholes are just on the muffler, and because i live in new jersey and everyone is assholes when i asked the guy at the inspection station what exactly was the problem he shrugged me off and told me to go to autozone and have them look at it
the code for it is P0441
i hate NJ and their gay car laws
Old 07-11-2007, 02:58 PM   #4 (permalink)
View toyomoho's Photo Gallery
Have a low cost muffler installed at a muffler shop.
The white smoke could be oil blow by or something else.
P0441 Evaporation emissions control system incorrect purge flow
The fuel tank is sealed to prevent gasoline emissions. The charcoal canister absorbs any gas fumes, stores them. The fumes are then directed to the engine to be burned when running. The system has a pressure sensor to detect if the tank remains pressured. If the tank depressurizes, the code is tripped indicating an air leak someone or one of the system components is not working.
Problem areas with this code: Vacuum hose leaks in fuel tank in emissions control system. Check hoses to the charcoal canister and VSV systems. Canister could have leak, defective VSV for pressure sensor or EVAP, vapor pressure sensor, fuel tank overfull check valve. Also check the gas cap seal.
Check the seal on the gas cap first, then or broken, plugged or damaged hoses in this emission control system.
Old 07-11-2007, 10:03 PM   #5 (permalink)
so most likely its just my gas cap o-ring or something stupid?
Old 07-11-2007, 11:35 PM   #6 (permalink)
View whatproblems's Photo Gallery
fuck NJ
i live here to, our laws are bogus....
but yes i have that same error code that pops up
i just disconnected the battery, reconnected it and it passed inspection... check engine light came on an hour later
whatproblems is offline   Reply With Quote
Old 07-12-2007, 12:10 AM   #7 (permalink)
Originally Posted by whatproblems
fuck NJ
psh, IL has 'em too. stop whining sally's.
it's really a good thing though, the e-testing clues you into problems that you might not otherwise know about.
Old 07-12-2007, 11:26 AM   #8 (permalink)
good news i patched up the holes with some crap lets hope it works! lol
Old 07-12-2007, 11:37 AM   #9 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
the holes can be patched up with a product called clay steel or something
its handled like clay but once dried, is super hard, withstands extreme temperatures, and resists chemicals
WhiteRabbit is offline   Reply With Quote
New Dual Exhaust spdlva2nv4eva Camry & Solara Lounge 10 04-29-2006 10:06 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
Q's about Borla dual exhaust for xB jemo xB Lounge 0 08-07-2004 07:54 PM
