1.6 or 1.8 on a 97 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2007, 06:57 AM   #1 (permalink)
View micmonty's Photo Gallery
USA 1.6 or 1.8 on a 97 Corolla
Hi Guys,
I'm looking for a head gasket kit on ebay and they only the only ones I found for my 1997 Corolla is for a 1.6 liter engine. My Mechanic (if you read my previous post you will understand why i'm going to you guys for help) says my 97 Corolla has a 1.8 liter engine. May someone please give me a brief history on what engine types were available back then and if I do have a 1.8 where can I find a head gasket set?
Thanks!
2007 Silver Corolla LE - 120,000 Miles and still going!!
1997 Tan Corolla DX - 266,000 Miles and still going!!
1997 Tan Corolla CE - #New edition# only 36,000 miles!!
micmonty is offline   Reply With Quote
Old 07-13-2007, 07:31 AM   #2 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
Your 1997 Corolla is an 8th Gen corolla(1997 - 2001). You have a 1.8 Liter 1zz-fe engine, as that is the only engine for the 8th gen.
Try your local pepboys/auto zone. they usually carry gaskets. If they don't have one, you can always go to toyota itself.
http://www.pitstopautoparts.com/ also has them, and I have used this site a couple times and have never had a problem with them.
Crowbar911 is offline   Reply With Quote
Old 07-13-2007, 09:26 AM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
check toyota and other places, I found with my 4af's headgasket toyota was By far the cheapest. $40 from toyota, and car quest wanted $80 for the low grade and $110 for the premium
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 07-13-2007, 09:44 AM   #4 (permalink)
on full afterburner
Gameroom cash: $1347397
Wrong
The OP said 1997. It's a 7th generation Corolla made from 1993-1997.
It came with a 1.6 4AFE and the 1.8 7AFE. To make sure, you should check the sticker under the hood of the car that should say what it is. Either that or the door jamb sticker, if it says AE101, then it has the 4AFE, if it says AE102 then it has the 7AFE.
Get your facts straight before posting.
Old 07-13-2007, 10:17 AM   #5 (permalink)
Crowbar911's Avatar
ok.
8th gen is from 98 - 2001 right?
My bad about that.
Old 07-13-2007, 10:19 AM   #6 (permalink)
Crowbar911's Avatar
How come my haynes manual covers 1993 - 2002? If thats two different Genereations, wouldn't they be different?
Old 07-13-2007, 10:21 AM   #7 (permalink)
on full afterburner
ok.
8th gen is 1998-2002
Old 07-13-2007, 10:22 AM   #8 (permalink)
on full afterburner
Lot of parts are interchangeable between them, for instance, both generations used the same suspension setup.
Old 07-13-2007, 11:06 AM   #9 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $143400
View Piloter's Photo Gallery
8th gen was engine refresh, radio/HVAC refresh, and slightly different front and rear lights. Nothing major changed otherwise, I think.
WIP AE102.
Piloter is offline   Reply With Quote
Old 07-13-2007, 12:07 PM   #10 (permalink)
View 94_Rolla_Guy's Photo Gallery
be sure the 4A uses a thick composite gasket while the 7a uses a thin 3 layer metal head gasket
be sure of what engine is in there use one of both of these 2 ways....
1. check the source look on the front right of the engine block, (right up against the tranny) about halfway down theres a flatspot that will give ya the real block code (7a / 4a)
2. the 1.8 liter has a aluminum stiffener that bolts to the bottom of the engine and to the transmission leaving a small black oil pan at the very bottom of the engine while the 1.6 has an all steel oil pan
right across the bottom off the engine..
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Minor questions about the 97 corolla. Driver Archived Corolla threads 6 07-31-2006 10:14 AM
'97 corolla having trouble starting after rain Ranger X Archived Corolla threads 4 07-24-2006 12:44 AM
97 Corolla CE Replacement Struts peterng Archived Corolla threads 0 07-04-2006 11:26 AM
My 94 Corolla DX is a 1.6 liter?!?!?!? Blazzin_One Archived Corolla threads 17 05-15-2005 01:26 PM
'97 Geo Prizm same engine as a '97 Corolla? jbattenhouse Archived Corolla threads 5 12-07-2004 11:50 AM
