brakes... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2007, 09:15 AM   #1 (permalink)
View whatproblems's Photo Gallery
brakes...
well, it sounded like the front left brake was going so i bought new brake pads...
i take the caliper off and check them.. they're full, there's no groove in the rotor, no nothing
but when i drive i hear a sound like the brakes are going (sorta like how some pads have the wear indicator)
any clue wtf this is?
whatproblems is offline   Reply With Quote
Old 07-13-2007, 09:28 AM   #2 (permalink)
rwd_3tc
View rwd_3tc's Photo Gallery
there probably cheap brake pads. use the oem ones. there more quieter
1981 Toyota Corolla TE71
1990 Toyota Previa
rwd_3tc is offline   Reply With Quote
Old 07-13-2007, 09:31 AM   #3 (permalink)
possibly, but it even makes that noise while the car is in motion without the brakes on...
Old 07-13-2007, 10:24 AM   #4 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
could it be the wheel bearings making noise? Check for play....
retiredat44 is offline   Reply With Quote
Old 07-13-2007, 03:38 PM   #5 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Check the caliper pins to make sure they aren't bound up. If so free them up and lubricate with grease. If they are bound up they can make the brake pad rub against the rotor. Also check the springs that run from one pad to the other on the top. If rusted or weak can cause the pad to rub as well.
90 GP is offline   Reply With Quote
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
1995 Camry LE Soft Brakes kentarver 3rd & 4th Generation (1992–1996 & 1997–2001) 14 10-17-2006 06:33 AM
Brakes, How are yours? Chazmanian 2nd Generation (2005+) 45 03-24-2006 03:18 AM
Changing Drum Brakes to Disk Brakes on 2003 LE DragonR6 5th & 6th Generation (2002-2006 & 2007-2011) 1 12-10-2004 04:07 PM
Conversion Kit - Rear Drum Brakes To Disc Brakes Nikolas Archived Corolla threads 5 08-20-2004 10:38 PM
