door handle removal 88 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2007, 07:38 PM   #1 (permalink)
just516in's Avatar
Gameroom cash: $146780
View just516in's Photo Gallery
AE92 door handle removal 88 corolla
how to change the outside door handles?!?!
thanks
justin
if there are any pictures it would make life soo much eaiser
just516in is offline   Reply With Quote
Old 07-17-2007, 12:27 PM   #2 (permalink)
87 FX20 GTS
View Kyle22rte's Photo Gallery
On most yotas you take off the inner door panel, and when looking inside you should see two bolts holding the door hadle in. use some pb or wd40 on these because the nuts are molded into the plastic of the handle and a stuck bolt will break the nuts right out of your handle, rendering it useless.
there are also most likely two linkages: one for the lock and one for the latch. I know the latch, and perhaps the lock, uses a plastic clip to hold the linkage to the handle. you sort of rotate the clip off of the linkage and the linkage can then be removed from the handle.
If the lock doesn't use a plastic clip then it most likely has a sort of snap ring or an e-clip that connects it to the linkage. These invariably get lost in the bottom of the door when they zing off, so have a magnet handy.
Kyle22rte is offline   Reply With Quote
advice on 88 corolla gen_x Archived Corolla threads 8 03-28-2011 02:46 PM
F/S or F/T (2) 88 Toyota Corolla GTS (looking for an 82-91 Supra) PICS INSIDE! jayboogie Car parts for trade or wanted parts 5 08-09-2007 03:45 AM
88 Corolla battery drain. albertmdh Archived Corolla threads 20 02-11-2006 09:29 AM
88 Corolla engine years garrett simon Archived Corolla threads 5 02-10-2005 11:24 PM
88 Corolla with Tercel Transmission? shogun6684 Archived Corolla threads 0 02-03-2005 12:38 AM
