Odd sound coming from my transmission - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-18-2007, 10:17 AM   #1 (permalink)
on full afterburner
Gameroom cash: $1347397
Lately, I've been noticing a high pitched whirring sound coming from the automatic transmission (A245E) on my 97 Corolla, it occurs from the second I start the car and continues whereever I drive. The transmission shifts kind of roughly at times and seems to hunt also.
What is the cause of this?
Should I be worried?
EDIT: Transmission fluid level is normal. Car has approximately 152,000km
Old 07-18-2007, 10:37 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
You sure it's not a serpentine belt? it almost sounds like what the belts would do when they're lose or ready to break.
Old 07-18-2007, 10:51 AM   #3 (permalink)
on full afterburner
Pretty sure, I just had my timing belt replaced last year, and checked the others for any wear or slack. Found nothing that would indicate this.
Old 07-18-2007, 11:09 AM   #4 (permalink)
View powellsd's Photo Gallery
are you getting the noise while u are idle? If so could be waterpump, alternator, Serp belt, Tensioner for Serp Belt
1993 BMW 325i Toy and Track Car
1990 Corolla as daily driver and winter car
powellsd is offline   Reply With Quote
Old 07-18-2007, 07:38 PM   #5 (permalink)
on full afterburner
Yes, the sound also occurs at idle
I looked over all those spots and found nothing out of the ordinary
Any other possible culprits?
Old 07-18-2007, 07:45 PM   #6 (permalink)
View 94_Rolla_Guy's Photo Gallery
are you sure its the A245L if its the A131L (3spd) its got a second case for differential oil. when they run dry the diff gears start to whine. it doesn't really seem to fit but....
If i were you i would invest in one of those mechanics stethoscope's or use a long screwdriver and take a listen its amazing how quickly you can find problems
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 07-18-2007, 08:46 PM   #7 (permalink)
on full afterburner
I have the 1.8L 7A-FE engine, it's a 4-speed automatic with overdrive
Old 07-18-2007, 08:55 PM   #8 (permalink)
if it occurs at idle then it wouldnt be your tranny. i bet you have a bearing going out on pully somewhere, still can be your waterpump, alt, powersterring, serp belt, belt tensioner. How old is all that stuff..
Old 07-18-2007, 09:17 PM   #9 (permalink)
on full afterburner
still all original, going on 10 years now, owned the car since new
Old 07-18-2007, 10:47 PM   #10 (permalink)
that is a pretty long time on that water pump, alt and other equipment..
Old 07-19-2007, 10:16 PM   #11 (permalink)
on full afterburner
Well, this is odd... it turns out that the sound wasn't coming from the transmission at all. Or at least I think.
I just got back from a trip stateside and before I left I:
-changed the oil
-used fuel injector cleaner
-filled up with premium gas
Oddly now, the sound is completely gone.... car runs smooth as butter, I don't understand what it could have been
Found a $350 camry, but not sure if i can fix it Figit090 1st & 2nd Generation (1983–1986 & 1987-1991) 37 01-02-2007 02:29 PM
93 Paseo transmission theflavor Tercel, Paseo, Starlet, and Sera Forum 2 07-11-2006 10:46 PM
"Buzzz" sound in the transmission box 03matrixr 1st Generation (2003-2008) 0 05-04-2006 09:53 AM
Humming/whirring sound coming from engine... meng-chieh Camry & Solara Lounge 22 06-16-2005 10:25 AM
'95 Camry, knocking sound coming from rear/trunk over bumps 95CamryLE 3rd & 4th Generation (1992–1996 & 1997–2001) 16 01-21-2003 09:12 AM
