engine replacement 1994 corolla 1.8, 245 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-18-2007, 11:26 AM   #1 (permalink)
View guacopo@hotmail's Photo Gallery
I am putting a new engine in my 1994 corolla. The crank is frozen, have tried everything to loosen it, but it won't budge. So I can't get the bolts off connecting the flywheel & torque converter. My question is: can I remove the engine with the t.c. still attached, and then put it back into the transmission after I have hacked and hewed to free up the crankshaft? I have never had this much trouble with an engine replacement before! and I don't want to have to remove the whole transmission. Thanks for any info/suggestions!
Will M
guacopo@hotmail is offline   Reply With Quote
Old 07-18-2007, 01:28 PM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
you try hitting the pistons with a wooden block from the top to free it up, might be a way to go
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 07-18-2007, 01:47 PM   #3 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
put some good penentrating oil around the pistons too and let sit overnight... then smack them with a wooden block, hit the block of wood with a heavy hammer.... (not too heavy, maybe a 3 or 5 lb.)
retiredat44 is offline   Reply With Quote
Old 07-18-2007, 02:48 PM   #4 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
The engine with frozen crank is in your car? To do either of above you need the head off. Just a friendly warning...
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 07-18-2007, 06:00 PM   #5 (permalink)
head is off already
and the # 3 cylinder has a fragmented tie rod, which has wedged the crankshaft in place. I have drilled out the top of the piston, used a sledsgehammer, crow bar, wd-40, everything I could tink of. That's why I want to know if the torque converter can come out with the engine or not--if the engine was out, I could take tio to the shop and have it cut out--I don't want to save any part of this engine--it's junk!
Thank you very much for your replies
Will M
Old 07-18-2007, 06:08 PM   #6 (permalink)
Question
can you cut the damaged rod with a dremel tool?
Old 07-18-2007, 06:41 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
drop both the engine and gear box.
Then when you get them out to the ground you can separate them most likely.
Old 07-18-2007, 07:49 PM   #8 (permalink)
the torque converter should just pull out of the transmission but... there is not enough room by far to pull the two apart in the engine bay, i think flashmn is right drop the whole crossmember onto a dolly or something then pull the two apart.
Old 07-18-2007, 10:46 PM   #9 (permalink)
I might try to cut out the piece that's jamming it---
or maybe I'll try dynamite!
Thanks for the replies.
Will M.
Old 07-23-2007, 09:55 PM   #10 (permalink)
got it out!
Ended up using a sledgehammer, a maul,, 2 crowbars, several drill bits, and finally a circular saw. I bashed that engine block to smithereens--would be funny if it was a core. It was the worst i ever saw. Now I'm an expert --new engine is in, I'll fire it up tomorrow.
Thanks again for your ideas.
Will M
Old 07-24-2007, 02:16 AM   #11 (permalink)
Chitty Chitty Vroom Vroom
View Criard's Photo Gallery
take luck with your new engine!
Criard is offline   Reply With Quote
Old 07-26-2007, 11:55 AM   #12 (permalink)
Exclamation
I take it the dremel tool wasn't an option?
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
HELP is '93 Corolla 1.6 interference engine? 93corolla5speed Archived Corolla threads 15 01-04-2007 07:10 AM
1994 Camry Engine Replacement, Any Tips? 96tauruslx 3rd & 4th Generation (1992–1996 & 1997–2001) 1 06-09-2006 05:44 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
