Overdrive is any gear that has a ratio of less than one. This means the input from the engine to the transmission is turning slower than the output from the transmission to the differential.
When you turn the car on, OD is automatically on meaning the transmission will shift 1st through 4th gear. Fourth is an overdrive drive gear. When you press the button and turn overdrive off, it will not engage 4th gear. It will only shift 1st through 3rd. Third gear has a gear ratio bigger than 1 so it is not an overdrive gear.
The torque converter only locks up in 4th gear on these cars so you also prevent the torque converter from locking up.
I only turn it off when Im driving in snow. depending how the roads are, I will also put it in second, or first. This allowme/forces me to go slow, and also allows me to engine brake. which is very helpful when driving in a foot, foot and a half of snow.
O/D is supposed to be switched off in steep uphill driving in order to prevent the transmission from shifting up to overdrive gear(4th). By switching the O/D off, essentially the car will stay in 3rd gear thus providing the necessary torque for uphill driving.
__________________ SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
If you keep it off during city driving, you will hurt your gas mileage. the corolla can go 35 mph and be in 4th, at 1250 rpms. at third, 1800ish. (rough estimates off the top of my head)
Drive your Toyota overdrive 'on', meaning light off on the dashboard
Drive your Toyota overdrive 'off, meaning light on on the dashboard,when going up a steep hill
feel free to modifly the above.
2005 Toyota Collora
110000plus miles
recalled ECM only major issue so far
Hankook tires model 727
best tires ever ...2 tires at
9/32 tread after 43000 miles
other two 7/32.
Perfectly engineered tires
--excellent ride..good on snow
lower priced than walmart's cheap brand tires
