Vibration Noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-22-2007, 08:28 PM   #1 (permalink)
View Jmana's Photo Gallery
Vibration Noise
I just bought a 94 Corolla with 110,000 miles on it (1.6 liter). The only problem with it is there is a loud vibration noise that starts at around 60 mph and gets worse the faster I go. I had it aligned, and put new tires on the back. The noise is from the front but the front tires look good. The wierd thing is when I put it in neutral, the noise goes away, so I would think that rules out wheel bearings or tire noise, even though that's what it sounds like. The axles are tight, so I don't think that's the problem. I visually looked at the engine and transmission mounts, and the look ok. What else could be causing this noise?
Jmana is offline   Reply With Quote
Old 07-22-2007, 08:40 PM   #2 (permalink)
Jeep Survivor
jrcrum's Avatar
View jrcrum's Photo Gallery
I hate to say it, but maybe it's the transmission or the torque converter. The fact that it goes away when it's in neutral seems to eliminate most everything else I can think of. Maybe CV joints could generate a vibration, but I would think they would also make noise at low speeds.
Chrysler products are very reliable as long as you don't try to drive them.
jrcrum is offline   Reply With Quote
Old 07-23-2007, 02:05 AM   #3 (permalink)
Chitty Chitty Vroom Vroom
View Criard's Photo Gallery
my cv joints are in need of repair and make noise at lower speed but not higher speeds, if that helps
Criard is offline   Reply With Quote
Old 07-23-2007, 06:28 AM   #4 (permalink)
I really can't see how there would be an internal problem with the transmission, it shifts perfect and the fluid looks and smells clean. Plus the guy I bought it from babied the car. Is it possible that the mounts need replaced? Do they get soft after a while? I know they look intact, but who knows?
Droning noise & vibration after pothole ToyotaCarFan The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 03-06-2007 05:12 PM
Strange Vibration Noise???? vultrix 3rd & 4th Generation (1992–1996 & 1997–2001) 2 02-06-2007 12:04 PM
Annoying-ass vibration noise Ukrainian102 Archived Corolla threads 13 09-15-2004 05:55 PM
