I think it should since the exhaust setup is similar (Toyota's money saving stunt made the 8400 rpm high breathing XRS come with the airbox from the 6200 rpm 1ZZ Corollas and the stock exhaust setup is almost identical). That is why I think exhaust should easily fit on 1ZZ with maybe small modifications required. Cold air intake will be different since the size of the engine is different causing the piping to be routed differently in the two engines.
If you want to be safe, you can order Borla axle back exhaust or Magnaflow full catback exhaust for 1ZZ Corollas (there is one for 2ZZ as well, which I think is almost identical).
I love my street performance 2. Sounds deep and throaty, but not very loud at all. I am quite sure it will fit on your 1ZZ Corolla. Only small tweaks might be required at best.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
