2002 Corolla - high idle, no CEL
Just bought this car today, 2002 Corolla with a 4 speed automatic, 100K miles. When I start it up cold, the idle is fine...where you would expect to be on a cold start. Once thoroughly warmed up, the idle is way too high, as high or higher than you would expect on a cold (winter) start. I don't have a tach, but I would guess its cranking 1300-1500 rpms.
There is no check engine light on. Yes, the light is operative, as it comes on with the key in the ON position before starting.
I looked under the hood, and no surprise, there is no idle adjustment.
What is wrong here???
I can take it back to the dealer but I don't want to if it is an easy fix...
