Very low idle. Possible vacuum leak? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2007, 01:13 PM   #1 (permalink)
Tuskanr's Avatar
View Tuskanr's Photo Gallery
As you may know, im a new recent owner of a 1988 Corolla GT-S AE92. Now when I drive it for 20 minutes or more and have to do stop and go driving. Or am just idling for a long period of time, the idle drops to around 400 and sometimes even 350,
Now the guy I bought it from says these cars when they have vacuum leaks idle really low. Now is that true? If so, how would i go around finding it? Tips? Questions? Comments? Concerns?
Id love to fix this so i dont have to worry about it dying all the time on me.
Also one quick thing, whats a good cruising speed for these cars. Like on the freeway? 65 seems decent, but @ 70 its almost 4k rpms. and at that constant rpm's Im afraid i will heat up the oil too much.
Tuskanr is offline   Reply With Quote
Old 07-29-2007, 01:20 PM   #2 (permalink)
View 93corolla5speed's Photo Gallery
I am suffering the exact opposite problem. When cold, my idle is too low; when hot, it is too high. As for your question, I think vacuum leaks tend to create a higher idle, not a lower idle. This is because the engine has another source of air from the leaking lines, and more air in the throttle body means increased throttle, and hence higher rpms.
93corolla5speed is offline   Reply With Quote
Old 07-29-2007, 02:42 PM   #3 (permalink)
Gameroom cash: $128200
View 90 GP's Photo Gallery
Check all the vac lines and then the plugs/ caps/ rotor/ wires/ gas filter, timing and idle speed . If you have fuel injection and have a MAP sensor ( mounted on firewall) check the vacuum line that runs from it to the manifold. Also check the EGR valve (if equipped) to be sure it isn't clogged up causing the low idle.
90 GP is offline   Reply With Quote
Old 07-29-2007, 05:08 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
I'd adjust the idle a bit higher.
You wont heat up the oil too much. When I'm going, I'm doing 90 or so mph. Revs are high I know, its because the transmission is VERY short.
Old 07-29-2007, 06:00 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I've drivin 4 hours doing 140 - 160 km/h and the revs are around 4 or 5k. It's fine, like flashmn said it's because the gears are short. Even ar 100 km/h it holds 3k rpm
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 07-29-2007, 08:55 PM   #6 (permalink)
Bitter's Avatar
Gameroom cash: $485950
View Bitter's Photo Gallery
2.5hrs at 3500 rpm (85ish mph) without any problems either. the A245E has a little longer gearing than you guys, even a sprint upto 110mph (180km/h) in 3rd and no ill effects other than a very rapid heart beat.
Old 07-29-2007, 09:22 PM   #7 (permalink)
Tuskanr's Avatar
Cool, thanks guys for your replies, I will check the idle screw and probabally just up it a lil bit, but I will also do all that maintenence stuff, hoses and all that, I will let everyone know how that goes.
1992 previa vacuum leak silviasalsa Previa Forum 1 07-11-2007 02:02 AM
vacuum leak hellonwheels Pre-88 Toyota Pickup/Hilux 4 01-02-2007 12:08 AM
No start in park, and low idle at cold start q.man06 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-25-2006 03:41 PM
Low Idle problem mox 3rd & 4th Generation (1992–1996 & 1997–2001) 4 09-06-2006 02:43 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 11:53 PM
