the basic warranty is over, the dealer won't cover the cost anymore, they want $780 for the pump, totalling $1100 for including labor..i got a quote from one of the parts guy for the pump, its only going for $314 and he can give me a discount putting it at $269...i own 2 other cars which are a 90 st185 and an 87 ae82 which i have done all the works to them because i trust no one....i only ask of this because i've never seen anything like it...when i was on the celica forums, there FSU cover have 8 bolts holding it down...but when i look at the rolla, its got a twist on type of ring that holds it down...reason why i'm doing it is because i need to test the pump to see if its still working, the car cranks but no gas, i've pull fuel line to check for gas and surely enough no gas. i've checked all fuses and relay, with a test light they all work and the relay clicks as it should...i've had similar problem on my st185 also but it was accessable so i fixed it, just had to drop the whole tank though.... thanks for being curious and bumping the post
87' FX16 GT-S
91" Celica Alltrac turbo
