What wire in my 94 corolla only has current when the engine is on? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2007, 03:37 AM   #1 (permalink)
View tlong831's Photo Gallery
I got a current tester, and I tested some fuses under my hood of my 94 corolla but none of them seem to only get current when the engine is on... I guess I will have to try the in cabin fuses? what is the best way to tap off one of these fuses?
I need a wire that gets current only when the engine is on to plug into my "battery brain" a device which monitor's battery voltage. thanks for any help.
tlong831 is offline   Reply With Quote
Old 07-31-2007, 03:50 AM   #2 (permalink)
View gasman's Photo Gallery
jus find a device that only turns on when engine is on such as blower motor or demister and tap off that. but make sure to check and double check first that it does have voltage to it.
Brake-Down Shift-Turn
gasman is offline   Reply With Quote
Old 07-31-2007, 09:14 PM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $486450
View Bitter's Photo Gallery
fuel pump
Bitter is online now   Reply With Quote
Old 08-01-2007, 02:50 AM   #4 (permalink)
so off the fuel pump? i dont want to go cutting open wires if i dont need to ? should i just go from the fuse? i think i was going to try to the wiper fuse... but that gets power when I am in ACC.. i dont know if that will mess with a battery brain
Old 08-01-2007, 11:21 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
I think black brown wire in the ignition harness... I wouldnt go for the fuel pump.
Old 08-02-2007, 04:03 AM   #6 (permalink)
some say that taking anything of off the fuel pump can hurt performance since the fuel pump may not be able to supply enough fuel in extreme cases
Old 08-02-2007, 10:42 PM   #7 (permalink)
View TCorolla1990's Photo Gallery
Dont take off the fuel pump, too risky, do as gasman said n take off the demister or sumthing like that, always the safest option to go off a luxuary then the necessities
TCorolla1990 is offline   Reply With Quote
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 07:20 PM
20r Engine Rebuild From Hell! nwdetectorist Off Topic 6 10-20-2007 10:19 AM
How do you warm up your car? kenratboy General Discussion 64 09-06-2007 12:20 AM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 01:54 AM
94 4afe into 91 Corolla fabbb Archived Corolla threads 4 12-11-2006 09:19 PM
