Outside temp -E or -30 in summer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2007, 10:52 AM   #1 (permalink)
View cheesycoolguy's Photo Gallery
I recently changed out my tachometerless instrament panel for one with a tach. Everything works fine except for the outside tempurature. Is there a way to calibrate it or do I need to go back to the junkyard and get the temp sensor? If so where on the car is the sensor located? Thanks.
1996 Tacoma V6 4X4 Ext Cab, 1999 Corolla VE
cheesycoolguy is offline   Reply With Quote
Old 08-01-2007, 11:40 AM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $296373
View Buurin's Photo Gallery
Check if you have the temp sensor. It looks like a plastic probe (similar to IAT sensor in your airbox but NOT THE SAME), mounted pointing down on the vertical pillar just ahead of your rad, behind your bumper - hood latch is mounted at top of that pillar. If you don't have it, go get it.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 08-08-2007, 03:13 PM   #3 (permalink)
The harness was in place, the guy at the junk yard gave me the little sensor and now I have the outside temp, thanks.
5w 30 in the summer ditchin 2nd Generation (2005+) 17 08-14-2006 09:15 PM
Temp. gauge sender? andyb16 MR2 Forum 1 06-06-2006 10:40 AM
Outside Temp Gauge- How to decipher true temp demoncleaner 2nd Generation (2005+) 19 05-17-2006 08:41 PM
Intake Air Temp. Sensor Check... 87_SR5 Archived Corolla threads 3 03-31-2005 06:35 PM
