2003 Corolla Le - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2007, 01:05 PM   #1 (permalink)
View johnnysouth's Photo Gallery
USA 2003 Corolla Le
Hello, I recently purchased a Corolla 2003 LE for my daughter from a used car dealer in Hialeah Fl I have come to realize that #1 their is no horn under the hood just a hanging wire harness and a tapped ground wire.
Also the #2 rear window defogger does not work all fuses have been checked and all is good #3 Outside temperature gauge located next to the odometer works ocassionally and has inaccurate temperature readings like -30 when its 90 degrees. any sugestions ?? Thank you Johnnysouth
johnnysouth is offline   Reply With Quote
Old 08-01-2007, 01:29 PM   #2 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
Take the car back to the dealer. I believe that to sell the car, the car has to be street legal, and since you have no horn, it is not.
(atleast in NJ, you need a horn to pass inspection)
not sure about the defroster.
Crowbar911 is offline   Reply With Quote
Old 08-01-2007, 04:12 PM   #3 (permalink)
FinalGear's Avatar
View FinalGear's Photo Gallery
Becareful!!
DOUBLE check your paper work and make sure the car was not sold as IS!!! If the motor still run strong and has good brakes and good tires.....if so, I think you got a good deal!
FinalGear is offline   Reply With Quote
Old 08-01-2007, 05:51 PM   #4 (permalink)
Whine connoisseur
View adsaba1969's Photo Gallery
clean the thermometer, it's behind the front grille.
Adding a new horn is a $10 project but I agree that to be street leagal it should have been sold with a horn.
The rear defrost button may be unplugged, but most likely you missed a bad fuse.
Check fuse 29 which is under the steering wheel, as well as 37 which is under there also and most likely the cause.
Your owners manual will point you to the fuse number locations.
adsaba1969 is offline   Reply With Quote
2003 Corolla windows BenG 9th Generation (2003-2008) 12 11-19-2007 04:23 PM
2003 Corolla S camryelaine Archived Corolla threads 3 12-14-2006 09:13 AM
I Need Your help on a 2003 Corolla LE- unbelievable story Smittay Archived Corolla threads 12 08-05-2006 08:49 PM
2003 Corolla Problem (Belt probably?) Jun118 Archived Corolla threads 4 07-03-2005 11:56 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
