2-speed engine fan? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2007, 09:31 PM   #1 (permalink)
View mhaselman's Photo Gallery
Question 2-speed engine fan?
94 1.6 liter. When temp is 80+, driving 60 MPH or over, in the sun, (weird) the temp gauge will start creeping up. I have to turn off the A/C to get it to come down, and if it's 90+ sometimes have to turn on the heat to get it to come down. Never happens at night. Just changed the stat and flushed and filled. Fans come on like normal. Question: do these have a 2-speed fan and how can I check to see if it's going to the high speed? Or it may be radiator time.
mhaselman is offline   Reply With Quote
Old 08-02-2007, 10:32 PM   #2 (permalink)
The TN Member
View punter's Photo Gallery
At high speed the fan will have little to no effect on air flow (think about how fast you drive through the air.)
Double check you have the correct themostat, have no airlocks, and that the radiator isn't blocked.
Something isn't working properly.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 08-03-2007, 07:52 AM   #3 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
Also, Check your coolant/coolant level. make sure you have no air bubbles in the coolant system.
Crowbar911 is offline   Reply With Quote
Old 08-03-2007, 08:01 AM   #4 (permalink)
Gameroom cash: $122130
View gideon1331's Photo Gallery
Another thing to check is your AC fan. It's the one on the front of the radiator assembly. It moves several times the amount of air as the normal engine fan when it kicks on, and can be noticably heard at idle. You will hear a very loud fan, and feel a rush of hot air if your foot is outside the door. If this fails to turn on, it could contribute to overheating.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
My Electric Fan Mod is Complete! Pb 2nd Generation (2005+) 116 08-13-2009 11:34 PM
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
Just purchased a new '07 LE (first post) with break-in procedures Forced Induxion 5th & 6th Generation (2002-2006 & 2007-2011) 9 07-17-2006 07:29 AM
Ignition Gas Usage? Spiffy_Vision General Discussion 11 09-30-2005 08:47 AM
