Originally Posted by toyotaspeed90
if you're concerned you can just swap the pin assemblies out..... they're only held in by the rubber boot
Great suggestion! The rod and clevis assembly is held in by a snap ring so I just put the old assembly on the new master cylinder. I think I could have used the new part as is but it didn't take a lot of effort to swap parts.
The clutch seems to be OK now. The problem was that sometimes the clutch wouldn't disengage and it was also engaging just off the floor. I replaced both the master cylinder and the slave cylinder. I replaced the slave cylinder first but that didn't fix the problem. Anyway just took the car for a drive and the problem didn't occur. The clutch seems to grab a little higher, not right off the floor, so that's probably a good thing.
Hey, great forum. From just a little bit of searching there seems to be a lot of knowledgeable and helpful people here. My daughter's car used to be her grandfather's and it's only got 58,000 miles on it. I guess with 12 years on it there are going to be issues with some of the rubber bits. We've also owned an '87 Nova and '90 Prizm, both great cars. (Yup, I work for GM
Now, if I can just find the engineer who put the master clutch cylinder behind the brake booster.
