Direction light duplicated with beeper question
Hello,
I would like to duplicate the direction lights with a small beeper - this way one
does not have to remember to turn them off in case the wheel rotation fails to do it
and most importantly - there's no doubt when you need to be 100% sure they're on !
My question is - where to connect it so it works for both (left and right direction lights) !??
(The easiest way would be to connect one beeper in parallel to each circuit - that powers the left and right direction lights - but this is not a smart way to do that !?)
The car is Toyota Corolla 1997 and there is easy access to the panel mounted just
below the steering wheel - where the wires are going to the lever switch.
Thanks for any suggestions !
