try this check with the engine cold take off the rad cap (fluid should be covering the top of the core if not top up) now start the car and run the engine up to normal temperature as the temperature gets hott you will notice a huge increase in flow across the open rad cap, soon after the fan should come on and the temp shouldn't go any higher..
Problems
- soon as you start engine while cold the rad starts over flowing = Rad plugged try reverse flushing it or replace it
- never see huge change in flow across open rad cap flowed by overheating = bad thermostat
- Fan never comes on and over heats = bad fan, fan relay, or fan switch.
It is only a single speed fan also if the water pump is only 2.5 years old theres no good reason for it to be bad,
you could also check the water pump fairly easily, take the belt off and turn it with your had you should feel a fluid like resistance, if you dont and/or the pump keeps spinning after you give it a good turn then it may be the pump but i doubt it..
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
