Engine mounts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2007, 06:49 PM   #1 (permalink)
View rangejeepjeep's Photo Gallery
Smile Engine mounts
I need to replace the engine mounts on my car and I can't tell which one has gone bad. Any sugguestions on which one I should replace first? Or is it best to just replace all 3?
I'm driving a 94 Prizem.
rangejeepjeep is offline   Reply With Quote
Old 08-06-2007, 07:31 PM   #2 (permalink)
View powellsd's Photo Gallery
if it was me i would replace all of them. Otherwise just go to each section and push on it and see what happens
1993 BMW 325i Toy and Track Car
1990 Corolla as daily driver and winter car
powellsd is offline   Reply With Quote
Old 08-06-2007, 07:48 PM   #3 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $143400
View Piloter's Photo Gallery
Generally it's the transmission mount that goes first and worst.
WIP AE102.
Piloter is offline   Reply With Quote
Old 08-11-2007, 11:04 PM   #4 (permalink)
I got the rear engine mount loose but can't get it out. It's stuck between the power steering rack and the engine support that stretches from wheel to wheel. Does anyone have any tricks on getting the engine mount out? The only soluction I can see it to drop the engine support to free up the rear engine mount. It looks difficult.
Please help.
By the way, since I'm working on the rear mount, should I just replace the front engine mount too?
Old 08-11-2007, 11:27 PM   #5 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $296373
View Buurin's Photo Gallery
Please help.
You may be looking at dropping the entire crossmember. But once that's out, taking out the front mount is easy.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 08-12-2007, 01:26 AM   #6 (permalink)
TIEyota fighter ace
Piloter's Avatar
If you just replace one, it'll make the others start deteriorating a little bit faster. If you've got everything apart far enough to do them all at once, why not?
Edit: Tried levering the engine a bit forward with a prybar or broom to get at that rear one?
WIP AE102.
Old 08-12-2007, 03:52 PM   #7 (permalink)
I was able to free up the engine support and replaced the front and rear engine mount. Thanks for the help.
Old 08-12-2007, 04:47 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I think theres 5 mounts all in all.
One near the radiator infront of the engine, one undernearth the engine and transmission, one on the rear of the engine, then left and right.
Old 08-13-2007, 11:55 AM   #9 (permalink)
92 Corolla 4AFE
View 91boz's Photo Gallery
How did you get the rear mount out? I tried to drop the center crossmember (the one running front to back) and the rear engine mount thru bolts are holding it in place. The mount itself cannot clear the steering rack.
92 Corolla 4AFE, 94 Camry LE V6
91boz is offline   Reply With Quote
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 09:38 AM
Part IV; 20R ENGINE REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 6 10-05-2006 11:28 PM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
Any way to jack engine from below to change all engine mounts? foomanji Archived Corolla threads 3 10-24-2005 11:22 AM
