Weird Corolla electrical issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2007, 05:31 PM   #1 (permalink)
View Bioguy's Photo Gallery
Hello Toyota Forum!
Ok, let me preface my plea by saying I know almost nothing about cars, and this is not an accident. I hate working on them, but then it comes back to bite me in the butt because I am so ignorant.
I was wondering if someone here might point me in the right direction to what is causing my problem. Here are the symptoms of my 2003 Corolla:
1. Three days ago my car stereo started losing its "memory". That is, it no longer remembers preset stations, tracts on CDs, etc. When this happens it is always in the "off" position so it appears it is losing power from the car battery when the car is off.
2. This only happens when the car has sat for 24 hours or more.
3. The car's dashboard clock is unaffected (keeps correct time)
Seems like it is isolated to the stereo except...
4. After sitting for 24 hours or more the car battery does seem "a bit" weaker. What I mean is, there is a small, but noticeable, delay in the starter turning over. Kind of like starting in very cold weather. I know this part isn't just in my head, because I noticed this before the problem with the car stereo.
I'm confused because I don't see how there could not be enough juice to keep my stereo from losing its memory, but plenty to start the engine? And, if it is just a problem with wiring of the stereo (or the stereo itself), then why is there a change in the power of starter?
Any information would be helpful. Thanks for reading.
Bioguy is offline   Reply With Quote
Old 08-07-2007, 06:24 PM   #2 (permalink)
FinalGear's Avatar
View FinalGear's Photo Gallery
Replacing Stero
Did you replace your stock stero?
FinalGear is offline   Reply With Quote
Old 08-07-2007, 06:40 PM   #3 (permalink)
Sorry, yes I did. About six to nine months ago, and I had BestBuy put it in.
Old 08-07-2007, 06:50 PM   #4 (permalink)
Whine connoisseur
View adsaba1969's Photo Gallery
It's not a battery issue, it's a stereo issue.
adsaba1969 is offline   Reply With Quote
Old 08-07-2007, 06:58 PM   #5 (permalink)
Thanks adsaba1969, but why would I have a noticeable drop in engine startup? Seems like quite a coincidence, no?
I am actually hoping it isn't the stereo, as that will probably end up being more expensive.
Old 08-07-2007, 08:00 PM   #6 (permalink)
Whine connoisseur
Check the power wires for the radio. They're usually red and yellow, with yellow being the constant to aid in the memory. Make sure there is a sound connection. Also make sure they're not reversed or wired together.
Could be coincidence about the startup because 03-04's are know to have an occaional turnover issue. I'm not refering to the 05+ cold start issue (if you've been searching).
Rarely an aftermarket stereo will use a battery in the faceplate to retain memory but that is uncommon.
Old 08-07-2007, 11:49 PM   #7 (permalink)
I will check that, adsaba. Thanks for replying.
I had wondered about a battery in the stereo itself. There is no mention of it in the manual, but those manuals are mostly worthless anyway.
Old 08-08-2007, 01:32 AM   #8 (permalink)
View 94_Rolla_Guy's Photo Gallery
a car radio gets a constant 12V all the time 24hours a day then it gets switched 12V from the ignition to turn it on with the Key, may want to have the wiring checked out, there could be numerous things wrong with it,
also dont hesitate to check the fuses for the radio some cars have 2 some only have 1, some radios will have fuses inline in there power wires behind them too, its possible there could be up to 4 fuses for the radio.
as for the battery getting low enough for the radio to loose presets theres no way it would start your car after...
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 08-08-2007, 09:34 AM   #9 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273721
View REN69's Photo Gallery
I had a similar problem with my battery just recently, my radio didn't keep all presets after turning the car off, but the car did start, slowly and weak but it would start, I changed the battery and the problem is gone now, turns out I killed the battery while I was doing my brakes the one day and had the stereo, amp, subs drawing power from the battery for a couple of hours.
Change your battery and see what happens, if the problem does come back with the replacement battery then your alternator is not charging properly anymore.
Old 08-08-2007, 11:31 AM   #10 (permalink)
Thanks to everyone for the replies. This isn't even really a "corolla" issue, and I appreciate your help with this minor annoyance.
Because of work schedule I haven't yet had the battery tested, and because I am an idiot I couldn't figure out how to get the lid off the fusebox this morning.
I'll have more time later in the week to tinker myself and/or take it in for analysis.
But... here's another thing I figured out about it. If I turn the key in the ingition part way to turn on the stereo all the memory is still there, but as soon as I turn it all the way to hit the starter I can watch it become scrambled!
That makes it seem less likely to be a wiring issue (which all looks ok from my untrained eye). Does that point more toward a fuse, perhaps?
Old 08-08-2007, 11:33 AM   #11 (permalink)
Thanks Rene69. That would be a good and simple fix.
Old 08-13-2007, 11:04 AM   #12 (permalink)
Lightbulb
Just wanted to close this thread out.
I actually did nothing for a few days. By the weekend it seemed clear to me that each day it was taking about a half second longer for the engine to turn over. That sure sounds like a battery going south... and it was.
Changed the battery and all is fine. Wish everything electrical was that simple.
Thank you so much for everyone that posted. I can see that some of the regulars around here can get a little tired of the noob technical questions. Understood, but it is very much appreciated.
Old 08-13-2007, 08:27 PM   #13 (permalink)
KDM is in
REN69's Avatar
Nice to hear we were of some help, keep an eye on the new battery though, if it starts happening again then you may still have a wiring problem somewhere.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 08-14-2007, 04:15 AM   #14 (permalink)
big_fella6699's Avatar
View big_fella6699's Photo Gallery
check the full time power wire, not the acc one, and make sure there is no visible damage, or the fuse( if it has one) isnt burnt out. if u can see neither of those... get an auto electrician 2 check it out
1988 ae95 corolla - extractors, pod filter - SOLD.
1986 mazda 929 turbo - 2.5" catback, boost cont, bov - DRIVING (for sale).
19** ke70 corolla, chopped springs all round, welded diff, more 2 come... - DRIVING.
big_fella6699 is offline   Reply With Quote
Toyota Japan Launches NEW Corolla Sedan & Fielder JoeyW Toyota News 31 12-07-2008 05:19 PM
Weird Corolla problem!@# diggittydoo Archived Corolla threads 3 09-09-2005 06:06 PM
Corolla idling issue after motor mount and CAI install. beholder Archived Corolla threads 5 08-12-2005 06:17 AM
Questioning the 2006 Corolla again...... RAV4EVR Toyota News 16 08-01-2005 12:26 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
