7a-f 1.8 Engine Problem ! I Need Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2007, 05:42 PM   #1 (permalink)
View WMATEO's Photo Gallery
The car starts but cylinder#2 is not working properly. The car sounds like when you are runnig out of gas. We have spark and fuel but no combustion. The ecu doesn't read any code. I unplugged the plug wire and the car stays the same unlike when i pull any of the other 3 cylinders. I raplaced the ecu but that was not the problem. I changed the injectors and that didn't work either. I replaced spark plug and wires and again that's not the problem. New spark plug #2 fouled the same day with carbon deposit meaning there is fuel. I know is not the engine becaused i replaced it also. The same problem!!!!! I guess is a wire problem that keeps the injector open. Anyone nows how to test to confirm it. Any suggestions or any different opinions. I need HELP!!!!!!!!.
WMATEO is offline   Reply With Quote
Old 08-07-2007, 05:45 PM   #2 (permalink)
ems
View ems's Photo Gallery
When you say replaced the engine do you mean it was rebuilt? If you just replaced it with a used engine you may need to do a compression test to see if it is o.k. It could also be a loose vacume line.
ems is offline   Reply With Quote
Old 08-07-2007, 05:57 PM   #3 (permalink)
bump!!!!!!
I went and bought another engine. I used the same ignition, and intake manifold from the old engine. I had rebuilt the original engine and the same was happening. The engine was rebuilt due to a toasted exhaust valve. I know the engine is not the problem or a vacum line. The problem is particular to cylinder #2. It comes down to injectrors. I tested injector #2 in cylinder #4 and it worked fine there but cylinder #2 with injector#4 still not creating combustion and the plug fouled again. I think something makes injector#2 stay open casusing the spark plug to fouled and cause no spark in cylinder #2.
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Emergency!!! Please Help! Engine problem! Something is broken and/or bent Blane Celica Forum 0 03-23-2007 08:57 PM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 12:54 AM
Really Weird Engine Problem... tre_03 Tercel, Paseo, Starlet, and Sera Forum 3 04-18-2006 07:18 AM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
