A/C questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2007, 11:08 AM   #1 (permalink)
View robk98's Photo Gallery
A/C questions
I have a 1997 Corolla, and the A/C is weak at best. I thought (hoped) it was the freon, but I checked the pressure and it reads 100 PSI, which I believe is full.
What is correct PSI?
So, any ideas on what this could be? How much should I expect to pay in repairs?
I called my usual mechanic and he said it was $150 just to refill and flush the freon, which seems rather high, so I'm a bit concerned about being ripped off. Then again I do live in Hotlanta, and it is an unusually hot august, even for us.
robk98 is offline   Reply With Quote
Old 08-09-2007, 09:57 PM   #2 (permalink)
FinalGear's Avatar
View FinalGear's Photo Gallery
A/C problem
If worst comes to worst...just remove the A/C units and free up some ponies power for your car. But $150 don't sound too bad in my book. WOW...at least you CAN AFFORD A/C in your car.....!!!!
FinalGear is offline   Reply With Quote
Old 08-09-2007, 10:24 PM   #3 (permalink)
Final Gear,
Living in Atlanta without A/C is like living in Denver without heat in; You could get by, but it's hard most of hte year. Its nearly 100 F with over 90% humidity here lately. A/C is a must.
The $150 was just the cost for a few pounds of freon (which between $10 and $25 in the auto store). So based on the 600% to 1500% mark up they're giving me, I'm a bit scared of having a compressor and/or condenser put in. I'd like to know what a fair price for an A/C repair is.
Old 08-09-2007, 10:31 PM   #4 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
I thot AC compresors get like 3lb of freeon or something close to that
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 08-10-2007, 08:38 AM   #5 (permalink)
View wiccanferret's Photo Gallery
Originally Posted by robk98
Final Gear,
A lot. AC is one of the most expensive things on the car to repair. What I usually do is have someone pump it ($20) then do the work myself, then recharge it myself. The parts are pretty pricy though. If you go this route make sure the first thing you add is AC compressor oil.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 08-10-2007, 09:04 AM   #6 (permalink)
blb
View blb's Photo Gallery
It reads 100 psi where and when? Is the gage hooked up to the suction line or high presssure line? Was the engine on and compressor cycling when the reading was taken? What was the ambient temperature when the pressure reading was taken? To properly diagnose the A/C system you must know, at a minimum, the suction side reading, high side reading and ambient temperature.
BTW, you don't fill and flush refrigerant like you do with coolant. If the system has leaked out refrigerant, an attempt should be made to repair the leak and the system refilled with the proper amount of refrigerant. The only time the system would require flushing would be if the compressor failed catastrophically and spread metal bits throughout the system. Then, the system would have to be discharged, repaired, flushed, a vacuum would have to be pulled on the system and then refilled with the proper charge.
If you can answer the questions above, we may be able to help.
blb is offline   Reply With Quote
Old 08-11-2007, 12:09 PM   #7 (permalink)
View toltec tacoma's Photo Gallery
robk98 the condenser in front of the radatior is cloged or dirty
toltec tacoma is offline   Reply With Quote
A/C Not blowing Cold Air garrand3006 Archived Corolla threads 4 08-09-2006 04:08 PM
Heat and A/C? dpenz 2nd Generation (2000-2004) 5 08-07-2006 06:38 PM
A/C Help biggieeb0y Camry & Solara Lounge 0 05-29-2006 05:26 PM
NEED HALP FAST A/C Question madmann29 MR2 Forum 8 08-11-2004 08:20 PM
A/C system questions Racke Camry & Solara Lounge 15 05-03-2004 03:57 AM
