Too much oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2007, 08:49 PM   #1 (permalink)
View mcmdm50's Photo Gallery
Too much oil
When chaniging oil in my daughter's 2006 Corolla, I loostened the drain plug & replaced the filter but forgot to drain the pan (that's a 1st). Anyway, I added the oil, tightened everything back up. I checked level & it looked wrong so I drove it 3-4 miles to circulate the oil through the system. The oil level was still high & it finally dawned on me what I did so I drained it all out & added the right amount. All seemd perfect but then the car started hesitating when accellerating from a dead stop or when turning a corner. Any ideas on what I screwed up?
mcmdm50 is offline   Reply With Quote
Old 08-09-2007, 09:40 PM   #2 (permalink)
FinalGear's Avatar
View FinalGear's Photo Gallery
Too much oil!!!
How many quart of oil did you use?
FinalGear is offline   Reply With Quote
Old 08-09-2007, 11:02 PM   #3 (permalink)
View root's Photo Gallery
Oil may have gotten sucked into intake. Do you notice any smoking out tailpipe?
root is offline   Reply With Quote
Old 08-09-2007, 11:04 PM   #4 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
I never take my pan off my 2001.
My oil change(including filter) should take 3.9 Quarts. I just use 4 and I have never have had a problem. It's only an extra .1 quart, and my dipstick reads a ;little high, but still within the marks.
If your fill needed 4.5 quarts, and you added 5, you *might* have a problem.
(i don't know the numbers for your year.
But as final gear said, it all depends on how much extra you put in.
Crowbar911 is offline   Reply With Quote
Old 08-10-2007, 08:09 AM   #5 (permalink)
I put 4 quarts of new oil in.
There is no smoking from the talepipe.
Old 08-10-2007, 09:01 AM   #6 (permalink)
Crowbar911's Avatar
A quick google search shows that you take 3.7 quarts, but That sounds a little low.
Check the dipstick. If its too high, let a little out at a time until its ok.
Old 08-10-2007, 11:11 AM   #7 (permalink)
View Tavel's Photo Gallery
the capacity is 3.7qts. So filling to 4 is kind of overfilling...but as long as you check the dipstick, no worries.
I always put 3.5 in, it reads exactly in the middle on the dipstick. I do this with any car that requires something like 3.7, including my nissan sentras.
Tavel is offline   Reply With Quote
Old 08-10-2007, 12:58 PM   #8 (permalink)
Oil doesn't sound like it was overfilled too much. You might want to take out the spark plugs just to check them anyway.
Old 08-10-2007, 01:17 PM   #9 (permalink)
Gameroom cash: $147537
If he didn't drain it and put 4L in, he got over 7L of oil in there.
Old 08-10-2007, 02:08 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Putting double the amount of oil in the engine isnt very healthy, especially driving with it.
FYI, oil level doesnt set by driving the car, the pump is working when the engine is running. Two mins should be enough for the oil to circulate and if theres problems that two mins will minimize any damage and you can inspect for leaks at the bottom pan. Just a tip for next time.
Old 08-10-2007, 04:56 PM   #11 (permalink)
View YODA'96's Photo Gallery
Hey there!
There is a fluid called "engine flush" I used once for an old truck I used to have. One drains one's oil, replases it with the "flush," and runs the thing for a bit. Then drains the "flush" out...and replaces it(and the filter) with new oil. It worked for my truck's engine...all hesitation and filth was removed...and the truck lasted me a long time.
-YODA'96
YODA'96 is offline   Reply With Quote
Old 08-10-2007, 05:19 PM   #12 (permalink)
Crowbar911's Avatar
^^Spam?^^
Im pretty sure that you should NEVER put anything other than oil into your engine.
Old 08-10-2007, 05:39 PM   #13 (permalink)
Just in case, also check your air filter. You stated no smoking out exhaust, so I don't think you overfilled to point of the oil getting aerated (foamy) by the crank hitting it and the oil getting sucked into intake. Extreme cases I've heard of is that piles of oil end up in intake, soaking filter, catching fire. But this is extreme case, and it would be preceeded by huge billowing smokescreen out of tailpipe of oil being burned in engine. Just to be safe, open up the airfilter & examine it.
Old 08-10-2007, 09:12 PM   #14 (permalink)
Flashmn was right. I ended up putting double the oil in. I only drove the car 4 miles with the double oil but yet after correcting the level, I now get a hesitation when accellerating. I did check the air filter and it was ok. The car is a 2006 Corolla with only 5,800 miles. Does anyone know if there is a fix for the hesitiation.
Old 08-10-2007, 09:45 PM   #15 (permalink)
BANNED
View w203's Photo Gallery
I don't think you can add double the amount of oil or even 5L+ into the 1zz engine... It will just flow outwards from the top.
What oil did you use? What filter did you use? Do you have any CEL?
w203 is offline   Reply With Quote
oil change interval question nomad 2nd Generation (2005+) 15 06-29-2010 09:01 PM
oh Snap! Oil Oil everywhere!! Shogun1011 Pre-88 Toyota Pickup/Hilux 9 07-09-2007 04:46 PM
Another oil change horror story! witxp 5th & 6th Generation (2002-2006 & 2007-2011) 16 05-13-2007 12:29 PM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 12:36 PM
Help!! Oil Puddle Under Engine Structureboy Camry & Solara Lounge 12 01-17-2003 12:04 PM
