1998 Cooling Fan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2007, 06:31 AM   #1 (permalink)
View danno98's Photo Gallery
1998 Cooling Fan
Hi, I have 1998 Corolla. The cooling fans are always on, even with the car not running with ignition key on.
I took the car to a garage. He hooked up scanner and nothing showed up.
Has any one seen this before.
Thanks
Dan
danno98 is offline   Reply With Quote
Old 08-10-2007, 10:30 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273721
View REN69's Photo Gallery
A scanner wouldn't show why they're on.. you need a new mechanic as obviously this one failed to see a possible electrical problem.
Old 08-15-2007, 11:21 AM   #3 (permalink)
View gizmoinva's Photo Gallery
Corolla Cooling Fan Running Continuously
I also have a 98 Corolla with the cooling fan running continuously. Is this normal?
gizmoinva is offline   Reply With Quote
Old 08-15-2007, 02:19 PM   #4 (permalink)
Solved problem.
Replaced AC switch.
Old 08-16-2007, 03:08 PM   #5 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I think both the A/C pressure switch and the radiator fan switch will cause that. It is a fail-safe-on system. If you loose control signal to the fan it will keep running, that way if your fan switch switch goes bad or the wire breaks, the fan will run to prevent overheat at a stop. Some Toyotas are like that.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
My Electric Fan Mod is Complete! Pb 2nd Generation (2005+) 116 08-13-2009 11:34 PM
electric cooling fan jja141 89-95 Toyota Pickup/Hilux 2 05-08-2007 08:20 AM
cooling fan trouble pinoyboi2006 MR2 Forum 6 04-20-2006 10:00 PM
Electric Cooling fan and Overheating riddlej Cressida Forum 0 12-19-2005 12:33 PM
cooling fan function related to ac high press switch chitowncelica Hardcore Tech and Competition 4 07-22-2004 04:15 PM
