Emission Fail - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2007, 08:28 AM   #1 (permalink)
View hamid2535's Photo Gallery
Canada Emission Fail
Hi all
my 92 Corolla Just fail the emission est only because of CO ( standard says :max=1 and mine is CO=1.2 for IDLE condition ONLY) every thing else is O.K.
Please advise what Can I do to drop that CO a little bit to pass?
thanx
hamid2535 is offline   Reply With Quote
Old 08-14-2007, 11:58 PM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
retard the timming a degree or two do the test then put it back to spec, that may work.
another thing to try would be to add gas line antifreeze / methyl hydrate (same thing) but you have to add quite a bit to make this work exactly how much im not sure of,
another thing worth a shot is a seafoam treatment, to clean the intake, valves, and combustion chamber.
other than that try a basic tune up, oil, spark plugs, cap and rotor, fuel cleaning, a
ALSO SEARCH 30secs on GOOGLE
IDLE EMISSIONS
A vehicle that has sharply elevated HC or CO emissions at idle will usually have a noticeable misfire and/or rough idle. The most likely causes here would be:
Fouled spark plug(s);
Shorted spark plug wire(s) or defective plug boot(s);
Vacuum leak;
EGR valve stuck open;
Burned exhaust valve;
Misadjusted throttle body air/fuel mixture; or
Misadjusted carburetor idle mixture.
An extremely rich fuel condition can also cause elevated HC and CO at idle, while an extremely lean condition will only cause HC to rise abnormally. A leaky EGR valve can act like a vacuum leak and cause a lean misfire at idle.
HC and CO will be somewhat higher as a cold engine warms up because the fuel system may still be running in open loop. Until the engine reaches a predetermined temperature and/or the oxygen sensor gets hot enough to produce a good signal, the PCM will supply a relatively rich mixture while the system is in open loop. A faulty thermostat that is stuck open or a defective coolant sensor may prevent the system from going into closed loop.
NOX emissions are always lowest during idle and decel because that�s when engine load and combustion temperatures are lowest.
Carbon Monoxide:
Measured in percent, this is the result of incomplete combustion. In other words, the fuel mixture has been compressed and ignited, but could not complete the combustion process due to the lack of oxygen. This failure is always mixture or ignition timing related. The ideal reading for CO is 0%. A normal reading for CO is usually around .25 to .75% with 1.2% being the failure mark in most areas for vehicles 1984 and newer. Earlier cars are allowed higher readings. Any car equipped with an Oxygen sensor will try to run under 1.0% as measured before the Catalytic converter (use that test connection for set-up). A vehicle with a CAT, O2 sensor, and an AIR system (Air Injection Reaction) will read almost 0% with everything working properly.
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 08-15-2007, 08:30 AM   #3 (permalink)
thank you rolla guy for response, I will do those.
one more question, I have found by reading that high CO is caused by Rich air/fuel , on corolla 92 do yoiu know how I can change that fuel amount? it is injection not carborat so I belive the sensors should control that, am I right?
If you have the chk engine light for the evaporative emission. toyota may cover it! popeye08 Camry & Solara Lounge 1 12-15-2010 01:01 PM
Do-It-Yourself : Check Engine Light - Diagnosis bonnie* Archived Corolla threads 5 01-01-2007 02:12 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
Inspection Blues Emission fail PBXJay General Discussion 4 06-21-2005 08:41 PM
Car Mods and Photo Radar in Toronto (56k'ers beware) 83SupraMk2 General Discussion 15 06-19-2003 10:23 AM
