2 dead cylinders... Need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-19-2007, 02:18 PM   #1 (permalink)
View atbader's Photo Gallery
I'm working on a 91 Corolla with the internal coil on the distribtor. The car is running on Cylinders 1 and 2, but Cylinders 3 and 4 are completely dead. There is air spark and fuel being delivered. I did a simple paper test for compression on cyl 3 and 4 and there is at least some compression. I'm getting an actual compression gauge to test it later tonight for some hard numbers. But my question to you is, if compression is fine in all 4 cylinders, what else would cause two dead cylinders? Any ideas would be of great help. Thanks for your ideas!!!!
atbader is offline   Reply With Quote
Old 08-19-2007, 06:07 PM   #2 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
if there is not enough compression it will not fire properly you may have a leak or something
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 08-19-2007, 09:58 PM   #3 (permalink)
Raging Raven
View TenZen's Photo Gallery
pretty much what daniel said. maybe the rings are going out of it.
2005 Dodge Neon SRT-4
Originally Posted by FinalGear View Post
gosh...those honda guys....as soon as they put the intake in their Civics...it goes faster than any Mustang, Evo, and Sti....
TenZen is offline   Reply With Quote
Old 08-20-2007, 02:07 AM   #4 (permalink)
92 Corolla 4AFE
View 91boz's Photo Gallery
If it is adjacent cylinders that are low in compression good chance that the head gasket is bad. Very unusual for rings in two cylinders to go bad at the same time.
92 Corolla 4AFE, 94 Camry LE V6
91boz is offline   Reply With Quote
rough idle at dead stop 1996camry 3rd & 4th Generation (1992–1996 & 1997–2001) 9 06-30-2007 08:06 PM
battery dead... Corollacrazy42 General Discussion 12 08-13-2005 11:24 AM
Dead Cyl. Donr Tercel, Paseo, Starlet, and Sera Forum 15 08-01-2005 10:28 PM
some help- wheel cylinders FRITO Camry & Solara Lounge 3 07-22-2003 08:41 PM
