cooling system - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2007, 11:26 AM   #1 (permalink)
View robertson's Photo Gallery
USA cooling system
coolant not being pulled back into radiator when engine cools. coolant level in overflow bottle stays same hot or cold. small loss of coolant ( 3-4 oz.) from radiator after use. new radiator new cap. 96 corolla with 135k not overheating. anyone out there seen that?
robertson is offline   Reply With Quote
Old 08-21-2007, 11:59 AM   #2 (permalink)
View toyomoho's Photo Gallery
Check for air leaks in the coolant system. The system needs to be able to hold pressure to draw in and force out the excess fluid into the overflow tank. Might be the radiator cap, the hose between the radiator and tank might also be plugged.
Old 08-21-2007, 12:40 PM   #3 (permalink)
thanks , checking for leaks is next step but beyond my ablity,so mechanic is next. aloha
Old 08-21-2007, 01:03 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I had that same issue... it was the head gasket (but I knew it).
It would suck in air from the cylinder and because its lighter, it wont suck in the heavier water from the reservoir.
Old 08-21-2007, 01:27 PM   #5 (permalink)
mechanic i just spoke with on phone also said head gasket and asked if water or smoke was coming from tailpipe. there is no water or smoke. can head gasket be slightly leaking and car not showing any obvious symptoms except no coolant transfer between overflow and radiator?
Old 08-21-2007, 02:17 PM   #6 (permalink)
blb
View blb's Photo Gallery
Originally Posted by robertson
Can head gasket be slightly leaking and car not showing any obvious symptoms except no coolant transfer between overflow and radiator?
Yes, although most people don't notice until the coolant level in the radiator goes below the point at which the car will start to overheat.
blb is offline   Reply With Quote
Old 08-21-2007, 02:33 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
yes, my headgasket didnt have any other problem, except for fluid loss. However its not very healthy for the engine.
Old 08-21-2007, 03:05 PM   #8 (permalink)
ok toyota nation now i can make an informed decision, mahalo
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Banks Monster Exhaust SR5-2006 2nd Generation (2005+) 30 08-28-2007 06:53 PM
Starlet - strange cooling system leakage M.T.Pilot Tercel, Paseo, Starlet, and Sera Forum 10 08-23-2007 12:46 PM
Idea for cooling system wildfire Camry & Solara Lounge 4 02-14-2005 07:13 PM
