Cooling fan on '05 XRS always on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2007, 10:51 PM   #1 (permalink)
View OCDetails's Photo Gallery
Is it normal for the cooling fan to always be running when the car is idling on the XRS? I'm only wondering because it seems that mine is always on. I don't like having a car that sounds like it is powered by an electric fan. I'm wondering if I've got a relay problem somewhere that needs to be replaced...
OCDetails is offline   Reply With Quote
Old 08-21-2007, 11:45 PM   #2 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
It happens in hot weather during summers for me. In cooler climates, you will see the fan does not run as often.
Remember, 2ZZ-GE has an air injection system that runs when the car starts up at idle and the oil temperature is cold. It usually runs for about 3 - 5 minutes to get the catalytic converter up to speed.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 08-21-2007, 11:58 PM   #3 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
do u have ur AC on??? with the AC on one of the fans is always on
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 08-22-2007, 07:07 AM   #4 (permalink)
Hmmm... now that you mention it, my AC probably is on at the time. That is a good observation and I'll have to test that theory. Thanks for that tip. Hopefully that is the problem. The time that I usually first notice it is when I get off work and go to pick up my kids. The car has been running for five to ten minutes by then and the fan is on from the time I get out of the car till the time I get back in it. Hopefully that is due to the AC being on. I'll give it a look and see if that is the problem.
electric cooling fan jja141 89-95 Toyota Pickup/Hilux 2 05-08-2007 08:20 AM
04 Corolla S vs 05 Corolla XRS warm up time silver04rollas Archived Corolla threads 12 05-21-2006 11:26 AM
05 Corolla XRS Recall silver04rollas Archived Corolla threads 5 01-01-2005 06:15 PM
05 corolla xrs mmartin1872 Introduce Yourself Here 21 08-28-2004 04:40 PM
cooling fan on all the time newbi Archived Corolla threads 15 04-27-2004 09:14 PM
