A/C Compressor rattles in reverse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2007, 02:11 AM   #1 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA A/C Compressor rattles in reverse
Hi...I have an 03 Corolla and lately when my car is cold and I'm in reverse backing out I have a loud rattling....This only happens when the A/C is on...I had a friend check it out as I had it in reverse with the break on and he said it was coming from my AC compressor when I shut my AC off under the load it stopped...It only does this when the car is cold and just a little bit in forward gear at start up then it smooths out when warm...Any experience this or have any ideas?...Thanks
Raddman is offline   Reply With Quote
Old 08-22-2007, 02:25 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Well your engine rotates the same direction regardless of which gear you're in.
Old 09-03-2007, 08:02 AM   #3 (permalink)
View jamesmetairie's Photo Gallery
yes
i have similiar stuff happening. i put the car up on ramps and could not find any thing loose such as heat shields ,cat converter,etc. i had someone start the car,then put it in drive and the rattling started.i put my head under the hood on the passenger side and i could hear the noise around the a/c or "tensioner".i,ll update you if i find a cure.
6&8.
jamesmetairie is offline   Reply With Quote
Old 09-03-2007, 10:31 AM   #4 (permalink)
Registered User
Raddman's Avatar
USA
Thanks...I haven't found out what it is ether, funny thing is that it goes away once the car heats up...
92 Celica ST - After 1 year of not driving A/C does not work Guitarlp Celica Forum 5 07-05-2007 03:46 PM
A/C always on; bad dash switch? bad relay? How to Test? ladd2 Camry & Solara Lounge 8 05-01-2007 06:11 PM
1998 Avalon A/C Issues ignoreme 1st Generation (1995-1999) 2 04-11-2007 10:47 AM
A/C Not blowing Cold Air garrand3006 Archived Corolla threads 4 08-09-2006 04:08 PM
