Ebay headlights install (AE102) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2007, 01:40 AM   #1 (permalink)
View desired_speeds's Photo Gallery
Hi, my friend has a 95 Corolla DX and he recently bought some JDM replica headlights off of advancedjdmparts.com that look like this:
http://www.advancedjdmparts.com/imag...roductid=16337
Now he wants me to help him install it. I know that the USDM corolla uses 9006/9005 bulbs with separate high/low beam. But these probably use H4h or something along the lines of that. What would be the best way to wire them up keeping the highbeams? Any help would be greatly appreciated. Thanks!
desired_speeds is offline   Reply With Quote
Old 08-23-2007, 03:00 AM   #2 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $143400
View Piloter's Photo Gallery
The Ebay headlights I have still use the 9005/9006, although they're a different style.
I believe there are H4 harnesses that plug into a 9005/9006 socket, though.
WIP AE102.
Piloter is offline   Reply With Quote
Old 08-23-2007, 04:36 PM   #3 (permalink)
I sure hope it comes with an H4 harness or else i have to go junkyard hunting again.
Old 08-23-2007, 06:05 PM   #4 (permalink)
FinalGear's Avatar
View FinalGear's Photo Gallery
Sweet
Those are NICE lights......
FinalGear is offline   Reply With Quote
Old 08-23-2007, 09:31 PM   #5 (permalink)
TIEyota fighter ace
Piloter's Avatar
On closer inspection, those have holes for both bulbs. I can see the shroud over the bulb opening for the low beam and the opening for the high beam separately. Your friend should be fine.
WIP AE102.
Old 08-23-2007, 11:08 PM   #6 (permalink)
that smaller bulb is a 194 for city lights
Old 08-23-2007, 11:28 PM   #7 (permalink)
TIEyota fighter ace
Piloter's Avatar
There shouldn't be a 194 in the main reflector portion, the 194s go in the side markers. This generation of Corolla doesn't have DRL...it sure looks like an opening for the 9006 bulb to protrude through, but I could be wrong.
WIP AE102.
Old 08-24-2007, 06:15 AM   #8 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
I have those lights, albeit the ones that are all silver on the inside.
You will NOT be able to plug them directly into the factory wires (even with adapter) since H4 bulbs have a common ground. On that model corolla, the low beams are ground switched, while the highs are 12v+ switched (or the other way around, i dont remember which.)
What I did was connect the factory wires to 2 $5 relays from autozone, one for low, one for high, so that both the high and low beams were now 12v+ switched like they need to be. This also allowed me to give the headlights a dedicated connection to the battery, which results in more consistant light, and headroom for high wattage in the future.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 08-28-2007, 02:44 AM   #9 (permalink)
Thanks for your help, I found a diagram on how to do this. Its exactly what you did. The headlights should be coming in tomorrow.
btw, do you have any pictures?
Old 09-17-2007, 05:38 PM   #10 (permalink)
edo0220
View edo0220's Photo Gallery
i need help
hey guys, i bought those lights as well, and i was just wondering how to istalling them.
especailly the city lights.
edo0220 is offline   Reply With Quote
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
Ebay Raises FEES - (AGAIN) SolaraTRD Off Topic 14 01-08-2007 09:45 PM
ebay headlights... (gen 3.5) l0n3xstar 3rd & 4th Generation (1992–1996 & 1997–2001) 14 01-12-2006 01:00 AM
5sfe Engine Install xylium 3rd & 4th Generation (1992–1996 & 1997–2001) 9 04-08-2005 02:07 AM
Today I install the new "Dimond Headlights" to my 92 Trueno92_HK Archived Corolla threads 4 04-30-2002 11:39 PM
