2000 Toyota Corolla CE Tachometer? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2007, 09:57 PM   #1 (permalink)
View KHSFilipino7290's Photo Gallery
I have been giving myself a headache trying to find out if I can put a tachometer from another corolla in my car... Do I have to wire the tach to the ECM or is it already wired in the harness? and is there a way to put my mileage in the new cluster?
KHSFilipino7290 is offline   Reply With Quote
Old 08-24-2007, 06:17 AM   #2 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
Your car should have the necessary extra wire for the tach already built into the plugs for the gauge cluster.
As far as I have read, since your mileage display is digital it is stored in the car's computer and should simply transfer over to the new cluster.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 08-24-2007, 02:21 PM   #3 (permalink)
View SBUBandit's Photo Gallery
The digital mileage is stored in the gauge cluster. If you swap the gauge cluster you will also swap mileage. However if you carefully unscrew the speedo from your stock gauge, you can swap it and thus take your mileage with you.
SBUBandit is offline   Reply With Quote
Old 08-24-2007, 03:17 PM   #4 (permalink)
Thanks guys now I can try this stuff out and see if I can get myself a tach i will let ya know how it goes...
Old 08-29-2007, 07:54 PM   #5 (permalink)
uhh hey i was able to install the tach and it works great i was even able to replace the speedo with my mileage but when i replaced the speedo taking it apart i took off the needle and now when i drive it seems as if i am going 20 when it says 30... is there anything i can do to see if its still ok or if i am still traveling at the right speed?
Old 08-29-2007, 11:40 PM   #6 (permalink)
View Tavel's Photo Gallery
why did you take off the needle? the speedo unit unscrews from the back...
I did this swap and it took about 5 minutes total...except I ended up having to rewire my harness to make the turn signal work properly (it was switched with the defroster for some reason).
uh anyway, recalibrating the needle is not easy. see the second to last post in this thread
gauge cluster
Tavel is offline   Reply With Quote
Toyota History BLUEMEANIE General Discussion 29 06-14-2009 05:56 AM
Parrot Bluetooth Handsfree Kit with Toyota harness! goldmember Car Parts for Sale 4 11-19-2007 04:51 PM
2000 Corolla CE Speaker Replacements (How) ak85lp Archived Corolla threads 15 09-12-2005 07:26 PM
In hybrids, it's Toyota vs. the world EKam Toyota News 2 03-27-2005 08:04 PM
