Hi All
My daughter has a 94 GEO with no brake lights. Everything else on the car works fine and they just stopped working.
I started with the simple stuff and worked into it but am now stumped.
Here are the areas I have checked and found OK:
1 - Fuses
2 - Bulbs
3 - Switch at brake pedal - removed and tested OK
4 - Wire harness from where it plugs into circuit box at drivers side - I traced the red/white wire from the trunk back to a plug and then fed 12v to the wire(lights came on).
5 - I pulled all, yes all, of the fuses and relays out, swap tested those I could and reseated everything. Nothing seems bad but I didn't take any to a store for testing. As I only have an older toyota manual and not the one for this car I have no idea if the relays would even make a difference with the brake lights.
I hope some one can help me.
