What's easiest way to reattach motor to right engine mount? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2007, 09:22 AM   #1 (permalink)
View adean1979's Photo Gallery
I'm finishing up my timing belt job tonight. Removed the front transaxle mount, used an engine hoist to lower the engine after I had done that and loosened the right engine mount, now I need to reattach the motor to the right engine mount. It's somewhat forward and not directly under the two bolts for the mount. Is there an easy way to push the motor backwards to get it lined up under the mount's two bolts? It will only be me by the way. My girlfriend could help late tonight after work if I hold the motor in place while she uses the engine hoist. Just physically using my weight to push the motor forward really doesn't do much to get it in place.
adean1979 is offline   Reply With Quote
Old 08-29-2007, 07:52 PM   #2 (permalink)
92 Corolla 4AFE
View 91boz's Photo Gallery
What year Corolla? On my 92 I attach the two studs on engine side first and then line up the thru bolt. How far forward is the engine? I should not move much.
92 Corolla 4AFE, 94 Camry LE V6
91boz is offline   Reply With Quote
Old 08-29-2007, 09:26 PM   #3 (permalink)
I figured it out. I had to rock the motor back and forth a little bit, push on it with all my weight, have my girlfriend line up the two bolts into the mount, and then she jacked up the motor with the hoist while I held it in place. It is almost back together now. I am going to quit for the night and finish up tomorrow night. God I cant wait to be done! It will good to have saved some $ though.
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 12:48 PM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 12:49 PM
How do you warm up your car? kenratboy General Discussion 64 09-06-2007 12:20 AM
'94 I4 Axels-Prices? instalation? pudbrother 3rd & 4th Generation (1992–1996 & 1997–2001) 18 04-08-2007 05:25 PM
Fr engine mount install update camry300 Camry & Solara Lounge 0 10-19-2005 11:25 PM
