High idle speed with P0505 and P0300 code
This is a corolla 2001, with idle speed 1500 RPM and P0505/ P0300 code.
Opened IAC valve and cleaned and reinstalled with new gaskets, confirmed at switching on, it initialize to close/open/ half open, but still problem persists.
Found that my TPS is out of range anyway, replaced TPS, but still problem is there. Meanwhile even with brand new TPS, still it shows from 11% to 40%, but the manual says it should show at least 64% while throttle completely opened.
Is my new TPS bad as well, Do I have a hareness issue from TPS or IAC to ECM?
All this problems started after removing Throttle body out for cleaning. I reinstalled that several times and now I'm positive that I installed Throtle body in right way with proper torques. Wondering one of cables (TPS or IAC) is being loose at connector.
Any advise appreciated.
Thanks
