Help! Speedo not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2007, 11:40 AM   #1 (permalink)
View sonyminidiscman's Photo Gallery
Hi... 94 corolla....... speedo just stopped working today as i was driving............. but everything else works.........temp gauge works, gas gauge works........... what can i do to troubleshoot..........?
94 corolla
http://www.cardomain.com/id/sonyminidiscman
sonyminidiscman is offline   Reply With Quote
Old 08-31-2007, 12:26 PM   #2 (permalink)
YYYOOOOUUUUHHHHHHHOOOUUU!
Rookie_One's Avatar
View Rookie_One's Photo Gallery
did you verify if the speedo cable is correctly connected (on the speedo itself and on the transmission)
Rookie_One is offline   Reply With Quote
Old 08-31-2007, 08:50 PM   #3 (permalink)
Where is it? what does it look like?
When i am on the highway, it'll go from 0 to 110kmh under 1 sec...........and stay there until i slow my car down to about 20kmh.......... does that mean its a loose connection?
94 corolla
Old 08-31-2007, 09:12 PM   #4 (permalink)
View toyomoho's Photo Gallery
Determine if you have a cable or a speed sensor. Find the trans then the differential. Look for a cable about 3/8 inch in diameter running out the top of the differential or if a electric speed sensor there will be electrical wires running to a sensor on top of the diff.
Might be a bad shaft inside the cable, bad sensor or speedo problem. The speedo could be getting too great a signal input from the speed sensor, be damaged, etc.
If the car has an automatic is it shifting OK, if a cruise control is it working OK and holding a steady speed?
Old 08-31-2007, 11:23 PM   #5 (permalink)
can i see that stuff from top of engine bay? or do i have to jack up the front to get to it from the bottom?
Its an auto... shifting like normal.........no cruise control........
man, its weird driving without speedo.....
94 corolla
Old 08-31-2007, 11:59 PM   #6 (permalink)
View 94_Rolla_Guy's Photo Gallery
the sender is at the back of the transmission by the rear mount try taking the plug off cleaning it with electronics cleaner and reinstall with di-electric grease. My girl friends did this, and i fixed it worked perfect for the last 10,000km
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 09-01-2007, 11:45 PM   #7 (permalink)
thanks...... is it easier to go from the top or the bottom?
94 corolla
Old 09-02-2007, 03:06 AM   #8 (permalink)
i would say top no way your gonna get at it from the bottom, also take out the intake duct pipe
Speedo Not Working TLM0719 Celica Forum 1 08-04-2007 04:06 AM
Gauge Cluster Weirdness - Coolant Sensor + Drive Light Not Working JayBroni 3rd & 4th Generation (1992–1996 & 1997–2001) 5 07-07-2007 10:31 PM
Bigger tires throwing off your Speedo? Sarkar 2nd Generation (2005+) 16 10-12-2005 02:44 PM
Broken Speedo, Help? Slip_87 ST Celica Forum 3 02-19-2005 03:34 AM
