Rust expert needed ! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2007, 12:41 PM   #1 (permalink)
View gregvdd's Photo Gallery
I discover some rust ... here :
I am planning to keep the car, 1 year or so, but need to be solid... do I need to weld or I can do it with glass fiber+bondo ??
What can this cost if I ask a bodyshop ??
gregvdd is offline   Reply With Quote
Old 09-01-2007, 01:02 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Yes you need to weld.. as for cost, its not going to be cheap.. thats really bad tho.
Old 09-01-2007, 02:41 PM   #3 (permalink)
Gameroom cash: $100900
View 4doorGTS's Photo Gallery
Thats the same problem I have with my ae92 sedan, both sides of the rear strut towers are rotten. I was going to weld patches in them I would not recommend bondo, but in reality if you do use it you'll be alright.
4doorGTS is offline   Reply With Quote
Old 09-01-2007, 03:11 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
No you wont be alright, thats a structural part of the frame. your SUSPENSION mounts to those. Now when they rust out, eventualyl, your suspension will snap them off and KABOOM you're dead when the rear gets wild.
Think twice about doing stupid shit onto your car.
Old 09-02-2007, 06:22 PM   #5 (permalink)
Actually yes he will be alright. He says he wants to keep the car for another year or so, even two years, there is no way ever that the rust will spread up tp the strut tower and corrode it away to the point of breaking in that time peroid. Its not that close to the top of the tower either. My car is worse than that and my car is lowered, has sway bars and gets driven hard often, no problems. Also that looks to be a wagon so most likely this guys back and forth to work commuter. I'm not saying drive it till the wheels fall off (or suspension gives through) but in the short term get your use out of it.
Old 09-03-2007, 12:05 AM   #6 (permalink)
View 94_Rolla_Guy's Photo Gallery
to temporarly fix that i would suggest fiberglass but, i would keep an eye on that closely, to do it properly cut out the rust and weld a patch in there thats the only proper way to fix it.
also i just noticed its on the frontside and backside of the strut tower, now i would suggest going and having it patched properly have metal welded in there.. im not gonna tell you fiberglass is safe to fix this because its not,
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 09-03-2007, 12:43 AM   #7 (permalink)
View Tavel's Photo Gallery
i agree, you can't use bondo and a bit of fiberglass to fix structural damage. You may as well do nothing if you fix it with bondo, honestly.
Tavel is offline   Reply With Quote
Old 09-03-2007, 03:03 AM   #8 (permalink)
BANNED
View w203's Photo Gallery
Welding is the best and safest way. Please don't cheap out with bondo and fiberglass because once you take a turn or when the weather changes (and force is applied) it will snap/crack and pop.
w203 is offline   Reply With Quote
Old 09-03-2007, 06:06 PM   #9 (permalink)
thanks for your opinion guys, I've be quoted $350CAN to fix it (weldings)
this is what I paid for the car...it is the only rust of the car...so I will probably do it...350$ is quiet a lot...around 6 or 7 hours of work...seems a bit long no
Old 09-04-2007, 12:10 AM   #10 (permalink)
Resident asshole
Flashmn's Avatar
With the amount of work you're going to do with bondo and fiberglass, its alot more than just welding a patch with spots. Then again, you cant weld rust, so you'd have to cut/grind that out first.
Old 09-04-2007, 12:14 PM   #11 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I'm with above the above posts. If he used bondo or fiberglass as a temp fix, since he's only planning to keep the car a year, he should be fine... Just don't be cornering hard or anything. you'd have to take it easy since if you didn't you'd possibly have the bondo or fiberglass just crack, fiberglass would be the best of those two... I would although ultimatly say that the only proper way and safest way for you and everyone on the road around you is to get it welded!!
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 09-05-2007, 07:49 PM   #12 (permalink)
Beautifully fixed by a small bodyshop in my street for a reasonable $225can...will try to post some pics tomorrow.
Old 09-07-2007, 10:27 AM   #13 (permalink)
Resident asshole
Flashmn's Avatar
One question though, you fix it with fiberglass and sell the car within a year and the new owner kills himself because he didnt realize it was fixed that badly. Who is responsible in your legal system?
Old 09-07-2007, 03:35 PM   #14 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I hope they actually cut and welded, for $225 cdn you probably only got some bondo and paint and a quick surface fix.
Old 09-11-2007, 08:30 AM   #15 (permalink)
It was very well fixed, cutted+ welded on the 2 sides.
For your info, when you sell a car from a private party to another private party, there is no legal guaranty.
Rust Proofing? xcomm 2nd Generation (2005+) 17 08-01-2007 06:22 PM
Rust - to fix or not to fix.. Pics (56K friendly) islandboy57 3rd & 4th Generation (1992–1996 & 1997–2001) 20 07-20-2007 09:24 PM
Rust oleum the under carriage of the taco?? scalder 2nd Generation (2005+) 4 06-29-2007 07:05 AM
Rust Todd Soden Yaris, Vitz and Echo Forum 2 07-07-2005 08:56 PM
rust protection koss78a Archived Corolla threads 11 11-16-2004 10:53 AM
