how to set timing? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2007, 02:12 PM   #1 (permalink)
View fuseone's Photo Gallery
how to set timing?
how do you set the timing on a 4age 20v or how do you make sure its right?
fuseone is offline   Reply With Quote
Old 09-01-2007, 07:10 PM   #2 (permalink)
any one know?
Old 09-01-2007, 07:53 PM   #3 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Originally Posted by fuseone
any one know?
Which timing?
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 09-01-2007, 11:04 PM   #4 (permalink)
cam timing
Old 09-01-2007, 11:14 PM   #5 (permalink)
Qslim's Avatar
The marks at the top of the cam pulleys and the mark on the crank pulley?
-- Get him, boy....
Old 09-02-2007, 12:32 AM   #6 (permalink)
good start but where they supose to be facing and on what stroke compression stork? at bdc or tdc? which one
Old 09-02-2007, 01:23 AM   #7 (permalink)
Qslim's Avatar
All you need to worry about is lining the marks up. As long as they are aligned, you can't be 180 degrees out. This is why there is a mark on the crankshaft and not just the cams. But if you want to check it manually, engines are timed at TDC.
-- Get him, boy....
Old 09-02-2007, 10:10 AM   #8 (permalink)
is there any where online that tells me how to set the timing for it?
Old 09-02-2007, 11:21 AM   #9 (permalink)
Qslim's Avatar
This is the best I can do for you, but I would really recommend finding yourself a manual for your car. Sounds like you're really getting into some stuff, and manuals are indispensable, especially if you don't have a lot of experience with in depth operations like timing belts.
BTW, this is out of your manual.
-- Get him, boy....
Low RPM buzz/vibration after Timing Belt Change---What did I do wrong? shackelton Camry & Solara Lounge 8 07-02-2010 09:52 PM
timing install issues!! F#(#!!! undertow29 89-95 Toyota Pickup/Hilux 3 03-23-2007 10:20 PM
timing trouble keereader Pre-88 Toyota Pickup/Hilux 12 04-04-2006 11:44 PM
timing trouble keereader Pre-88 Toyota Pickup/Hilux 0 03-27-2006 11:50 PM
