7afe wiring vs 7afe wiring? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2007, 10:18 AM   #1 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
will the wiring instructions for a 7afe celica work for my 7afe corolla when installing a safc2? i DO have the fsm in print here to reference, but its easier to just look at the pinouts from 6gc.net on their nice instrictions. i'd assume the pinouts between the fedspec 7afe's in the celica and corolla would be the same but i'm not sure. or if someone has a link to a set of instructions for the 7afe corolla?
Old 09-03-2007, 12:04 PM   #2 (permalink)
7AFTE's are fun
trancedcorolla's Avatar
View trancedcorolla's Photo Gallery
Lol they aren't exactly the same, you would be better off with a wiring guide manual. I had to put in an SAFCII for mine and it was a bitch. I forget what I did though lmao, I'll check my ECU later and tell you what I did if noone has a guide.
Edit: Do not use a guide unless it's 100% your car. Also the 7AFE changed in '95, so you can't use that guide. And Apexi is a whore and doesn't have the 7AFE's engine guide.
trancedcorolla is offline   Reply With Quote
Old 09-03-2007, 12:21 PM   #3 (permalink)
Bitter's Avatar
i have a 93 and the guide is for the 94 celica, same engine, same pcm, should be the same pinout....i think. like i said i do have the FSM here to consult for my car.
Old 09-03-2007, 01:59 PM   #4 (permalink)
Bitter's Avatar
ok, i got it all pinned out except my rpm signal. i see on the pinout for my pcm that theres a crank angle high and crank angle low. which if it is those 2 do i use?
Old 09-03-2007, 02:06 PM   #5 (permalink)
7AFTE's are fun
Yea, I tried to use the one from 6gc but it wasn't a match. I'd love to help more but I completely forgot what I did.
Old 09-03-2007, 02:17 PM   #6 (permalink)
Bitter's Avatar
doh! you and your forgetfullness have doomed us all, doooooooomed!
shucks, theres not much floating around on this topic either. if you do remember please please post it up. i think i have only one of 2 choices here, i just dont know which! or would it work to figure out which wire feeds the signal to my tach and splice that wire?!?
Old 09-03-2007, 02:27 PM   #7 (permalink)
Bitter's Avatar
ok bud, see if you can remember if its the ignition failsafe input or the ignition signal? i did a little more looking and found a little more here, i think its between these 2. please advise!
Old 09-03-2007, 04:13 PM   #8 (permalink)
Bitter's Avatar
fuck! the C3 connector on my car is totally different from in the service manual!
c1 and c2 match perfect, but c3 doesnt and it has grounds and rpm signal!
Old 09-03-2007, 05:38 PM   #9 (permalink)
7AFTE's are fun
Lol, what wires haven't you connected yet on the SAFCII? I'm gonna crack it open tomorrow in case you still need it, cause apprently I'm a dumbass and forgot to put in my turbo timer I have laying around. And then everyone can have it!
Old 09-03-2007, 06:35 PM   #10 (permalink)
Bitter's Avatar
ok, i got it wired correctly finally! long story, stupid tired mistake! now im having a hard time with the setup of it. i think i have it set right but i must not since it wont start. can someone call me and help me through this part? these directions that come with it SUCK!
Old 09-03-2007, 06:50 PM   #11 (permalink)
7AFTE's are fun
What's your number? I can help you with that lol
Old 09-03-2007, 07:46 PM   #12 (permalink)
7AFTE's are fun
I'll call you again tomorrow and give you a step by step wiring because your phone keeps crapping out on me lol. You have almost everything hooked up it sounds like, so I'll call you tomorrow and tell you what I have.
Old 09-03-2007, 08:15 PM   #13 (permalink)
Bitter's Avatar
i put the airflow signal wire back to stock and it started so it was something there somehow! also i'm seeing no rev on the safc2? i think i tapped the wrong thing for rev? let me know those 2 things, i am in your debt bud!
Old 09-04-2007, 01:20 AM   #14 (permalink)
View 94_Rolla_Guy's Photo Gallery
be careful because there were 2 versions of the 7a-fe the OBD1 and the OBD2 your talking about crank angle hi and lo your dealing with a 95.5-97 or OBD2 version, make sure your looking at the correct wiring diagrams. I had one in my OBD1 94 and it worked fine.
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 09-04-2007, 08:25 AM   #15 (permalink)
7AFTE's are fun
Yea we both have the same exact one.
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
4afe to 7afe ranterc Archived Corolla threads 4 03-06-2007 01:14 PM
7AFE ECU wiring diagram / pin out? jwetzler83 Archived Corolla threads 2 11-21-2004 09:03 PM
7AFE ECU Wiring jwetzler83 Archived Corolla threads 3 10-19-2004 08:38 AM
head light wiring.. Jzs147-RR Archived Corolla threads 0 08-27-2003 07:26 PM
