I/H/E 99 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2007, 07:21 PM   #1 (permalink)
View joeyb649's Photo Gallery
Question I/H/E 99 corolla
I've decided I want to pull an I/H/E job on my 99 Corola CE (4 door, 5spd)
My question is what to buy... obviosuly Intake,Header, Exhaust. I've found all theese products for my car. But, because of my lack of automotive knowledge, I don't know witch to buy. I want to get the most acceleration and horsepower I can harness from an Intake,Header, and Exhaust.
Suggested Products?
Dyno Proven?
I have about $800 to spend
: I would rather not have a cold air intake because it gets "freezing" in Connecicut in the winter and i'm told if water is sucked into the engine it can seize it. (correct if i'm wrong)
Those are pretty much my only stipulations
joeyb649 is offline   Reply With Quote
Old 09-03-2007, 08:21 PM   #2 (permalink)
BANNED
View w203's Photo Gallery
You won't be able to pull it off with 800 dollars unless the parts are used/crappy/ghetto rigged. Nitrous would fit your budget but unsure of what you want in terms of acceleration.
w203 is offline   Reply With Quote
Old 09-03-2007, 08:28 PM   #3 (permalink)
7AFTE's are fun
trancedcorolla's Avatar
View trancedcorolla's Photo Gallery
Lol you can pull this off easy with some common eBay parts that name brand whores overlook.
- Bomz Short Ram Intake
- OBX or Megan Headers
- OBX or Megan Highflow Cat (Or just gut your cat out. Unless you live in a state where they do emissions checking.)
- The knockoff Tsudo N1 on eBay sounds great and holds up well. Also fits well. If you find any brands on eBay you see that you like, just post them up here.
Other than that, those are the only proven cheap brands that actually fit/work. If you want name brand stuff, then it's gonna cost you more.
And with what I just gave you, you will probably have money leftover.
However, if you do want to get the most bang for your buck, just go by a nitrous express system.
trancedcorolla is offline   Reply With Quote
Old 09-03-2007, 08:35 PM   #4 (permalink)
I'm lookin at some parts on ebay right now but i can't tell whether the K&N filter is worth 25-30 dollars more then the other intakes when it only claims 5 more hp.
K&N =
OTHER ONE
also look at this turbo i found for about $600+ less then all others
http://cgi.ebay.com/ebaymotors/V-BAN...spagenameZWDVW
Old 09-03-2007, 08:41 PM   #5 (permalink)
I'm looking at the Bomz but its $70.00 -shipping witch i mean dosn't kill my budget, but i dont want to buy something $25 dollars more that is not giving me any more performance.
Old 09-03-2007, 08:50 PM   #6 (permalink)
7AFTE's are fun
70 dollars doesn't seem right, that's alot of money for an intake.
As far as the turbo goes, I'll say it on every post, don't buy those eBay turbos.
Old 09-03-2007, 08:59 PM   #7 (permalink)
I can't find any obx parts for corollas
Old 09-03-2007, 09:15 PM   #8 (permalink)
BANNED
Nope, wasn't referring to the name brand ones. But they are proven to work and fit. The parts on ebay have not been tested. Why short ram and not cold air? OBX/Megan/etc generic parts do not all have perfect fitment. They were not benched tested to increase power. Still have yet to see an dyno chart from them. Don't even bother with the hi-flow since they are crap, take a look at the inside and how long they last. Not my money, I just advise against them. Why are not more people using them?
Old 09-03-2007, 09:23 PM   #9 (permalink)
FinalGear's Avatar
View FinalGear's Photo Gallery
Missing parts
Gaskets, bolts, springs, and those damn 02 sensors!!!!!!
FinalGear is offline   Reply With Quote
Old 09-03-2007, 09:40 PM   #10 (permalink)
I'm actually thinking about buying nitrous but I don't know that facts.
How long dose a 10lb bottle last in general?
Its not being wasted if you have to slowdown the car for example in a circuit race rather then a straight up all out drag?
Is it expansive to refill (price range)
and just anything you can tell me
Old 09-03-2007, 09:58 PM   #11 (permalink)
FinalGear's Avatar
Wet or Dry...
You be lucky it you can get through the first shot..without messing up the motor....
It's easy to install and cheap....but the damage they cost without prior setup will be costly...please do some extra research...I know that you are itching burn rubber!!!! But save your hard earn money and do a little bit of research...You'll thank yourself later!!!
Old 09-03-2007, 11:46 PM   #12 (permalink)
BANNED
Nitrous is safe if you choose the right ones with the precautions like colder spark plugs and added fuel (depending on shot size). Things to consider is do you want to run a dry shot or a wet shot, do you want to run the 50hp shot or the 75hp shot or even 100+hp shot. Of course the higher the shot the more the danger. If you research enough and know the know hows its safe. Most people have the common mentality that nitrous will blow up your engine. Too much F&TF. But as Final said, research is key.
The amount of nitrous in a tank depends on your finger. Cost depends on your refill station. I'm not sure what your asking by the circuit racing and drag racing.
Old 09-04-2007, 08:22 AM   #13 (permalink)
7AFTE's are fun
I know alot of friends who use these parts, and I have used them as well for long periods of time wiith no trouble. The reason I say short ram is because he said he only had 800$. The money he would have to pay for a cold air isn't worth the VERY small hp gain he would get from a cold air intake. I tested my car with both cold air, and then short ram on numerous occasions and the numbers didn't change much. Also he says he doesn't know alot about cars, so a short ram intake would be easier to figure out. It's a pipe with a hole in it and a filter on the end.
Old 09-05-2007, 01:42 PM   #14 (permalink)
Okay so i've bought my Intake. Next is headers and exhaust any suggestions?
Old 09-05-2007, 06:46 PM   #15 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
Suggested Products?
Dyno Proven?
You're afraid of hydrolocking. Yes that would be bad. But if you point your intake downwards and don't place it too low, it isn't likely to suck in water.
The really cheapest way to do it is to pull off your stock intake and exhaust headers, do a porting (there's DIY floating somewhere doing this on a 1ZZ engine, involves grinding the ports smooth with a Dremel), and put it back. Parts wise you'd only be out the money on intake, exhaust and exhaust donut gaskets. Even if you send it out for a machine shop to do it (the shop I got my flywheel resurfaced calls it flow matching) it's about $200 per side, still within your budget.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
Toyota Japan Launches NEW Corolla Sedan & Fielder JoeyW Toyota News 31 12-07-2008 05:19 PM
Cold Air Intake '99 Corolla Chjpeter Archived Corolla threads 23 08-17-2007 11:54 PM
99 corolla exhaust TIP aaronwood06 Archived Corolla threads 8 08-01-2007 07:34 PM
'99 Corolla in Washington D.C. DinktheRolla99 Introduce Yourself Here 0 12-15-2006 12:05 PM
