Originally posted by mr_sinister
it's probably cheaper to buy one from an engine importer.. but first you should ask yourself if you really need an engine swap.. i'm sure there are a whole bunch of other things on the car that might need attending to..
if your engine runs fine, why not run it..
I agree. If your engines strong, keep it. Do a compression test, change the timing belt, and keep her fluids changed regularly. If you can afford it, take your time and bebuild an old engine that has stoped running.
