Nuke the XRS reverse beep - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-04-2007, 09:53 PM   #1 (permalink)
View OCDetails's Photo Gallery
Pretty simple mod. Only one screw involved. Take the bezel off from the gauge pod. One screw right in the middle. Then disconnect the harness on the left side of the top of the pod. Cut the red wire with the black stripe and all is completed. Wrap the ends of that wire with tape to avoid a short later, or just wire an LED to it to notify you in quieter ways that you are in fact in reverse. That is, if moving backwards under power isn't a big enough clue already.
OCDetails is offline   Reply With Quote
Old 09-04-2007, 10:39 PM   #2 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
You did not have to do that. There is a cheat code (sequence of pedal dance, holding the key etc.) to disable the beeper.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 09-05-2007, 10:18 AM   #3 (permalink)
Yes, but since nobody seems to post the magical 'up up down down b a b select start' code for the beep, I had to find another way. If I want it back (not likely) then I can always reconnect the wire. I spent ten minutes trying to figure out the code for the seat belt chime disable. It was much more satisfying to just clip the wire than dance in the car. lol
Old 09-05-2007, 01:58 PM   #4 (permalink)
Moderator
Originally Posted by Evil Corolla S
is it really that much of an annoyance?
Dunno. Not to me, for sure. I kind of like the beeping.
BTW, here is the cheat code to disable the reverse beeping.
Turn on the ignition and then wait 12 sec and then push trip meter button
Old 09-05-2007, 05:21 PM   #5 (permalink)
It bugs me, so that's why I cut it off. To each his own I guess. I've been driving for a long time and I've never thought to myself, "Gee, I wish I had a beep to let me know when I was in reverse." Besides, I did the seatbelt thing to get rid of that beep and it came back today. I don't want the reverse beep ever coming back to haunt me. Clipped and done with.
Old 09-05-2007, 07:00 PM   #6 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
You should have extracted the lead from the plug. A 1mm flat precision screwdriver is all you need and it's not destructive like clipping wires is.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Reverse Beep pstnhead84 Archived Corolla threads 7 10-29-2006 07:27 PM
Reverse Beep wildss MR2 Forum 5 09-16-2006 10:58 PM
XRS Reverse Beeping - can't take it anymore. dawg Archived Corolla threads 9 10-19-2005 09:12 PM
XRS Reverse? Lockout? XRS5002 Archived Corolla threads 6 04-28-2005 04:50 PM
XRS Reverse Warning Beep. flow 1st Generation (2003-2008) 3 01-18-2005 07:13 PM
