Flywheel Torque specs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-05-2007, 07:49 PM   #1 (permalink)
View Big block Ford's Photo Gallery
Hi everyone. I was hoping someone on the forums may be able to give me the torque settings for the flywheel bolts on a 5A-FHE engine. It has a manual gearbox and is in a 91 Corolla. Thanks .
Big block Ford is offline   Reply With Quote
Old 09-06-2007, 05:34 PM   #2 (permalink)
Ok then does anyone know a site that may have the settings. I want to bolt the flywheel back on, torque it up and get the sucker rolling.
Old 09-08-2007, 02:23 PM   #3 (permalink)
View toyomoho's Photo Gallery
The 5A-FHE does not seem to be used in the USA, as such no data. Suggest you call a Toyota dealer, auto repair shop, etc. The bolts specs for other simular engines run from 56-60 ft-lbs. Of find a standard torque chart for the diameter, pitch and grade of these bolts.
Old 09-08-2007, 06:51 PM   #4 (permalink)
YYYOOOOUUUUHHHHHHHOOOUUU!
Rookie_One's Avatar
View Rookie_One's Photo Gallery
5A-FHE, those exists??????
i tought there was only the 5A-FE
Rookie_One is offline   Reply With Quote
Old 09-09-2007, 04:46 PM   #5 (permalink)
Thnx for the replies.
The engine is in an FX Corolla and is a higher performance spec than the 5A-FE.
I did as suggested and called the local dealer. The torque settings were as toyomoho had thought and were 58ft/lbs.
Thanks. It should be back up and running in a few days.
torque specs dwmmatt23 2nd Generation (2005+) 13 02-04-2007 01:36 AM
Engine to trans-axle bolts torque specs call831 Camry & Solara Lounge 2 05-30-2005 12:48 PM
Anyone know torque specs for P/S pump bolts Robert K Camry & Solara Lounge 0 04-21-2005 11:26 PM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 09:54 AM
