SC not boosting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-05-2007, 09:38 PM   #1 (permalink)
View ekamakk4agze's Photo Gallery
SC not boosting
i need help.. my SC is not boosting we dont know why.. there is no leak in tne SC.. any ideas what might be the problem.. any info will help... tnx
ekamakk4agze is offline   Reply With Quote
Old 09-06-2007, 12:14 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
belt slipping?
Old 09-06-2007, 12:47 AM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
is the super charger finished?
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 09-06-2007, 06:28 PM   #4 (permalink)
View kevlar corolla's Photo Gallery
Is the pulley actually receiving power and locking up?,could be a break in the wire or the ground not connected etc.
The belt needs to be really tight btw.
kevlar corolla is offline   Reply With Quote
Old 09-06-2007, 08:47 PM   #5 (permalink)
its a non-prius ha
AzN-BriaN's Avatar
View AzN-BriaN's Photo Gallery
have u gotten it tuned??
AzN-BriaN is offline   Reply With Quote
Old 09-16-2007, 10:02 PM   #6 (permalink)
the SC is engaging.. and the wiring is good.. but its stilol not boosting properly.. the boost is bot consistent.. sometimes its 1psi then 3psi then 1psi then 2psi the most i got was 4psi. everytime i step on the accel the boost is deifferent... there are 2 vsv that are required in the vacum line and mine are not connected they go straight up.. is that the problem...??
Old 09-17-2007, 03:42 AM   #7 (permalink)
The TN Member
View punter's Photo Gallery
The vacuum lines need to be connected correctly for it to work.
Here is the factory diagram, with it connected like this you should get approximatly 8 psi.
Which is the max the early bigport pulley can manage anyway.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 09-18-2007, 07:29 PM   #8 (permalink)
Gameroom cash: $134355
yes and no.....
i would guess that if he's using a stock ecu then the vsv's might need to be hooked up
however, the s/c itself can work directly off of a switch (which is what I did in my old gze Megasquirt mr2)
you could have a faulty bypass valve
Game: ABC's of Geography VegasDriver Off Topic 34 04-10-2007 12:14 PM
Sc 12 and SC 14 S.C on honda. salmang MR2 Forum 4 08-26-2006 11:07 AM
Lexus Introduces Limited Edition Pebble Beach SC 430 Sportivo Concepts Toyota News 5 08-16-2004 12:37 PM
