For last couple of days, coolants level inside my coolant tank was lowered even I had top up the tank couple of days ago. Anyone knows if there is a problem or should I consider normal?(I am sure no leak due to new radiator and new coolant host couple of days ago due to leak)
When you put in the new coolant, did you run the engine, and top up the level with the idle up? It takes doing this to ensure no air bubbles are present. You may have just topped it up due to that. Monitor it from now, to see what happens.
Check the Rad, not the bottle, the bottle is for overflow, if it was full, and now its not so full, it could be due to the above statement.
There are those who do things, and those who take credit... The trick is to be in the first group, there is a lot less compitition.
what wunderboy is explaining is how to bleeed the cooling system....make sure you turn your heat on to while doin this, it also opens up your heater core which is part of your cooling system..
oops, forgot to check for your temp sensor...i'll do it tomorrow
Originally posted by rated_w it can also be a blown headgasket.. how many km's on your car?
werd, ur engine could be consuming that coolant.
i have a headgasket prob too..
__________________ The boro guru geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
headgasket can be the problem.. my old car had a headgasket blown at 225000 km.. is your exhaust like lots of white smoke? even if the engine is warmed up?
if so, it might be a cracked block (possibly), damaged cylinder head, or just a simple headgasket.
if you do the repairs yourself it'll cost about $300 bucks (what I did >> new gaskets, head bolts, rad hoses, fluids, oil, new filters, alternator (it was bad too)),.. (for a v6) .. assuming since it's an old car.. it should be around there because the parts are harder to find .. shops will charge anywhere from 800-1500 for this and it is somewhat of an extensive job.
I didn't do much....just flush the radiator and refilll coolant into it. Run the engine until it warms again...follow procedures as wunderboy mention....is ok now....except I hear some strange sounds when the fan is on.....try to use WD 40 to lubricate but still no use...
