Overheat buzzer warning system ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-08-2007, 04:36 PM   #1 (permalink)
randini667's Avatar
View randini667's Photo Gallery
Lightbulb Overheat buzzer warning system ?
Hello,
I'm looking to put in a over heat warning system and would like to ask if anyone has seen one for the Corolla/Prizm? Something with a buzzer would be what I'm looking for. Let me know what you think or if you have an idea.
-Ran
randini667 is offline   Reply With Quote
Old 09-08-2007, 04:51 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I dont see much use in it.
Old 09-11-2007, 12:44 AM   #3 (permalink)
View toyomoho's Photo Gallery
You might need to install another temp sensor into the cooling system that switches on a certain temp. Wire this to a small, low wattage buzzer in place of the normal temp light.
Keep in mind if the dash has a temp light the sensor is a switch that when tripped by over temp grounds the wire from the light and completes the circuit. If an analog temp gauge, the sensors resistance changes with the coolant temp.
Old 09-11-2007, 07:55 AM   #4 (permalink)
randini667's Avatar
Originally Posted by toyomoho
temp light (the sensor)
Piggy back off the temp light sensor.... Of course! I have a parts car, so I can strip out an apprioprate wattage buzzer. I'll double check the wiring diagrams. Thanks.
-Ran
Old 09-11-2007, 12:20 PM   #5 (permalink)
Gameroom cash: $147537
Just fix it so it doesn't overheat. When the light turn on, its too late already.
Do-It-Yourself : Check Engine Light - Diagnosis bonnie* Archived Corolla threads 5 01-01-2007 02:12 AM
Alarm system buzzer (Piezo buzzer) myt90 2nd Generation (2005+) 1 08-23-2006 09:28 AM
04 to 05 difference? Canada Jeff 1st Generation (2000–2006) 13 12-19-2005 03:40 PM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 01:41 PM
could you get away with it bondobondo General Discussion 46 07-06-2002 12:00 PM
