Originally Posted by REN69
Buurin just did an Auto to manual conversion on a ZZE110 Corolla, I don't recall him saying he had to switch from an auto to manual ECU.
I did switch ECU.
Originally Posted by ae924afdx
Rookie One...
i am swapping that motor in.. because of multiple reasons that are not related to BECAUSE IS A 1.8. And in my opinion the 7afe is not worth it {power wise/plus i have a fresh rebuild 4af with a 32/36}. I was going to swap a 4age {turbo} in but.. this is dayli driven. I got a 44k miles 1zzfed from a 02 celica with wiring and everything.. and this engine is LIGHTER than the 4a's and more than the 7a. Makes MORE power. Is newer in general.. and it will be unique.. i havent seen that much people swaping 1zz/2zz in ae92s. Those are my reasons. I already have 2 ae86's to play with.. a to be 3sgte ae86 and a regular gts coupe.
Let me guess. Accomplishment factor. You want a project.
Resistor Hacks? how does that work?
yea.. that's true.. is getting kind of boring. but.. whats the RESISTOR HACK?
Originally Posted by vibebreaker
ask dr tweak
Short answer: Hook a number of big ass resistors to the ECU to fool it into believing that the shift solenoids in the auto tranny (which is gone after the swap) is still there. If not done, you will get CELs.
That said, you are actually looking at an engine swap rather than manual conversion. You're going from A family to ZZ family. Tranny for ZZ family is C59. So I'm not sure if your C52 bolts in. But if it does, you only need to fabricate one engine mount.
Good luck.
